help getting into the trunk of my box caprice - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 01-16-2011, 09:26 PM Thread Starter
Monsta Mayne's Avatar
I have an 89 chevy caprice ..it doesn't have an electric switch to pop the trunk open. I don't have the keys for it either...I was trying to see the best way of. Opening the trunk without damaging it.
Any help would be nessasary...I want to rekey the car too.
Monsta Mayne is offline
post #2 of 11 (permalink) Old 01-16-2011, 09:54 PM
Mr pogo's Avatar
if it has a license plate light above the plate you might try removing the lens and light.
then use a long screwdriver thru the opening and hit the trunk release from inside.
Mr pogo is offline
post #3 of 11 (permalink) Old 01-16-2011, 10:09 PM
killerzracing71's Avatar
Send a message via AIM to killerzracing71 Send a message via Yahoo to killerzracing71
Break the lock.
Yeah, its held on with gum, staples and tape, only because I ran out of 5 50 cord.
killerzracing71 is offline
post #4 of 11 (permalink) Old 01-16-2011, 10:28 PM
bwebb's Avatar
go to dealership with vin # and they should be able to make u a key for just a couple bucks
http://www.cardomain.com/id/bwebb
'95 dggm caprice b4u
bwebb is offline
post #5 of 11 (permalink) Old 01-16-2011, 10:50 PM
purpkaka23's Avatar
[QUOTE=bwebb;2456153]go to dealership with vin # and they should be able to make u a key for just a couple bucks[/QUOTE
after 10 years they dump alot of info for chevys out of the computers when you go to the dealership they can make a key but it might run you like $20 and up. they charged me like $70 for a key but it had the chip in it also
Jets fly over lames, bow ties till i die
purpkaka23 is offline
post #6 of 11 (permalink) Old 01-17-2011, 12:25 AM
A locksmith can make you a key on the spot. If you don't want to damage anything, that's you best bet.
Jim B.
fbi9c1 is offline
post #7 of 11 (permalink) Old 01-17-2011, 01:32 AM Thread Starter
I'm gonna try to hit the release with the screwdriver first...I just want to see what's inside before I sell it
post #8 of 11 (permalink) Old 01-17-2011, 09:45 AM
Bigdawg70's Avatar
Remove back seat long arms and long flat screwdriver you can pop trunk. Most likely the key has been changed beforer i wouldnt count on dealer way. The liscene light is the easiest though it may be riveted.
Always a work in progress
Bigdawg70 is offline
post #9 of 11 (permalink) Old 01-17-2011, 01:01 PM
bwebb's Avatar
[quote=purpkaka23;2456163]
i paid like $6 for my door n trunk key
bwebb is offline
post #10 of 11 (permalink) Old 01-17-2011, 01:40 PM
HuSSker's Avatar
I'd go this route.
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
