factory security in 9c1? - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 11-28-2012, 01:02 PM Thread Starter
Got a 95 9c1, th8s shop is tryn to tell me there a factory security system on my car. I'm pretty sure he's blowin smoke.
Philly9c1 is offline
post #2 of 13 (permalink) Old 11-28-2012, 01:08 PM
He's probably referring to the VATS system.
post #3 of 13 (permalink) Old 11-28-2012, 01:19 PM Thread Starter
Would that allow the car to star then cit it off cut tho. And would u have to find codes to clear it
post #4 of 13 (permalink) Old 11-28-2012, 03:19 PM
Hamilton Chevrolet's Avatar
9C1's do not have the vats system so that every officer could get in any car and have them all keyed the same for their department. There was no vats in the cruisers that I have ever seen.
Mike--Hamilton Chevy
Hamilton Chevrolet is offline
post #5 of 13 (permalink) Old 11-28-2012, 03:40 PM Thread Starter
So he's blowin smoke basically. And it s an NYPD car
post #6 of 13 (permalink) Old 11-28-2012, 04:52 PM
As Mike stated, no VATs systems in 9c1's.
Jim B.
fbi9c1 is online now
post #7 of 13 (permalink) Old 11-28-2012, 07:21 PM
To be absolutely correct, there IS a VATS system in '94-'96 (and maybe earlier) 9C1's, but it is disabled. There is a white wire under the dash that takes the place of the resistor circuit through the key. With this, the VATS module always sees full reference signal voltage, so the car will always start and run. Also, 9C1 VATS modules never 'learn' a resistance value because of this. In my old '95 9C1, I tapped into this white wire and added a hidden toggle switch under the dash. Switch on, all is well. Switch off, and the car will not stay running on the next startup.
2005 Pontiac GTO
cletus284 is offline
post #8 of 13 (permalink) Old 11-28-2012, 08:19 PM
95wagon's Avatar
To be really accurate, it's half there
The theft deterrent relay is not there on the 9C1
The start wire goes directly from switch to starter.
The VATs module's sole purpose is to "tell" the PCM it can run the injectors.
Cletus , you say the VATs module never learns a resistance value.
So are you saying it is still "green " and could?
I was under the impression , and possibly wrongly, that the 9C1 module had learned that no resistance is required
Gerry
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #9 of 13 (permalink) Old 11-29-2012, 11:07 AM Thread Starter
So u just ran a two prong switch on the wire? U got a pics
post #10 of 13 (permalink) Old 11-29-2012, 04:48 PM Thread Starter
[Is this it on the drivers side over the ebrake attached to a green connector
