So how many 9C1's came with crank windows. - Chevy Impala SS Forum
 1Likes
post #1 of 22 (permalink) Old 08-06-2014, 08:17 AM Thread Starter
Picked up a 1994 9c1 formerly a code enforcement car from the city of Brewton, Alabama... Just wondering how many actually had crank windows. I will need to replace the driver and passenger door panels at some point.... Just seems like it will be a little odd since I haven't seen many with crank windows.
rjeftw is offline
post #2 of 22 (permalink) Old 08-06-2014, 09:00 AM
Not really sure if anyone could answer your question on "how many" cars have Crank windows. Maybe someone has a set here in the color you need. Be aware that the 94-96 panels look similar to the 91-93 panels but they are slightly different I believe due to the dash.
If you find the Panels with the Crank are a tough find, might be a good excuse to add in Power Windows. I doubt the wiring will be there and you will need to find a donor car for the harness and possible window regualtor and Motor. Not sure what else may be required, but it would seem to be a fairly nice project to consider.
You could also consider PWR Window panel and cut the hole yourself for the crank assuming the panels are the same minus the crank hole. It would be a shame to cut up a perfectly good door panel though. At least on the fronts which have the window switch on the Bezel so nothing to cover there. The rear Panels would be different and have a rectangular opening in them for the window switch.
I've added Pwr mirrors and Seats to my car using factory parts from a Donor/Junkyard car and had to make up my own harness to run between the pigtails. It wasn't difficult and schematics are readily available.
Another thing to consider if/when you remove and replace your door panels....look at the thread on the Window roller replacemnet. Might be a good idea to check those carefully and consider replacing the dog bone style while the door is apart.
post #3 of 22 (permalink) Old 08-06-2014, 01:16 PM
jayoldschool's Avatar
The rear panels are the same, the fronts are completely different. On a crank car, the armrest/control panel does not extend as far forward as on a power car.
Common? Common enough. Many municipalities ordered crank cars. My 94 OPP 9C1 was a pretty good stripper. Cranks, no posi, no radio, no cruise. Expect to find them in Light Adriatic Blue...
jayoldschool is offline
post #4 of 22 (permalink) Old 08-06-2014, 09:27 PM
No Moa's Avatar
Most all maine SP cars I've seen where crank windows.
1995 9C1
06 CTS-V
2002 CETA 700 original miles.
No Moa is offline
post #5 of 22 (permalink) Old 08-08-2014, 07:34 AM
The difference in the panels is the top front section. If you can remove and replace that section, you can make the older ones fit the newer ones.
I have a set of older ones that I repaired. You may be able to repair the lower section of yours, just like building a plastic model car. That part is styrene, and can be repaired with MEK or MEK substitute.
post #6 of 22 (permalink) Old 02-10-2017, 10:02 PM
dwascher's Avatar
I'm looking at doing this on a 9C1 I just picked up, I have a donor wagon with all the power options.
Rear doors on sedans and wagons the same? Since there are no window motors in the hand crank doors and they are riveted in, I'm thinking of swapping the harness that I need from the donor car and also just change the whole door. It'd be ALOT easier.
Dan (formerly known as 'z28coprice')
95 Caprice 9C1
95 Caprice Wagon (for parts)
94 Caprice Wagon (for parts)
94 Caprice Wagon (gone)
94 Caprice 9C1 (gone)
dwascher is offline
post #7 of 22 (permalink) Old 02-10-2017, 10:36 PM
This is a really old thread you have resurrected.
The front doors on the wagons and sedans are the same, but the rears are different. The difference between the sedan and wagon door panels is the top rear. The rear wagon doors are not compatible with the sedan. The wagon rear door interiors are different as well. The top rear has a larger cutout, and may not cover the end of the glass reveal. 91-93 front interior door panels are different in the front upper quadrant. The rear interior door panels are the same physically, but the colors are different after 94, and can be different in some 93s.
If you want electric windows, all you need to change are the regulators, the interior panels, and add the wiring. The donor regulators can be bolted in, rather than riveted. The wiring is part of the cross car harness, and you need to swap out the entire harness. It should be a plug and play. You may need the wire protectors that go between the door and the body for all four doors. The cross car harness for the wagon is a little different than one for the sedan. I suggest that you get a harness from a sedan. You may also have wiring for the seats, mirrors, courtesy lights, and electric locks. If you get a harness with provisions for the remote locks, you can install the module for that as well.
post #8 of 22 (permalink) Old 02-10-2017, 11:15 PM
dwascher's Avatar
I already swapped in the interior lighting harness and swapped in the upgraded rearview mirror with map lights and lighted hooks for the back seat. I was going to take out the harness from the wagon for everything wired to the doors and swap it over and either just hot wire it in with a fuse, or attempt to install the factory setup in the fuse panel. The second option looks difficult from a glance due to the wiring being tucked in at the back of the dash, not very accessible. My problem is that I'm trying to make everything from the wagon work so I can just swap as much as possible. It's going to be very difficult, and expensive, to find a set of good door panels in tan for the rear doors.
95 Caprice 9C1
dwascher is offline
post #9 of 22 (permalink) Old 02-10-2017, 11:18 PM
dwascher's Avatar
Also wanted to swap in the harness from the wagon so I can use power seats which my 9C1 doesn't have, like about all of them.
95 Caprice 9C1
dwascher is offline
post #10 of 22 (permalink) Old 02-11-2017, 09:18 AM
Are you looking for cloth top or vinyl top door panels? Do you have the pull handles or just the inserts?
