Drag racing question - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 04-02-2012, 09:25 PM Thread Starter
Crime Scene 96's Avatar
Ive been studing track racing videos for a while now, and ive noticed something interesting exhaust wise. I only see one of the following:
1. A simple pipe diameter no larger than 2.5 inch all the way out.
2. Open headers
3. Turndowns
But ive never seen anyone with big tips or tails pipes larger than 2.5 inch.
Anyone care to explain?
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
Crime Scene 96 is offline
post #2 of 13 (permalink) Old 04-03-2012, 01:18 AM
JZ9C1LT1's Avatar
Large tailpipes are basically for show, doesn't do much with horsepower.
There are some cars running 3" pipes all the way out the back.
96 9C1 LT1 with all the bolt on crap (Gone 1/08 to 9C1 heaven aka junkyard!)
95 9C1 LT1 New toy as of 6/09 (this one is now heading same direction as the 96)
95 9C1 LT1 The new black mariah! SOLD
95 9C1 LT1 Will be my 13/14 winter project
04 GTO SOLD
Originally Posted by BewbZowt(+ Y +)
Here's how it works: If I can see them, they are real.
JZ9C1LT1 is offline
post #3 of 13 (permalink) Old 04-03-2012, 08:24 AM
Blue Wail's Avatar
Most cars with 3" pipe have the exhaust system dumping right in front of the rear axle to avoid the restriction of the bent pipe going over the axle. That is why you don't see 3" tailpipes. My drag car is this way.
-Nab
10.87 @ 121 mph (MD Int' Raceway 11/14/2016)
Dry 150 shot through MAF (.062 jet)
Junk 355, Stock Iron heads; CC502 cam
4500 ati Turbo 400 4.56
9C1 'Anteloupe' 3300 lb
(World's lightest full-frame Bcar)
Blue Wail is offline
post #4 of 13 (permalink) Old 04-03-2012, 10:03 AM
The pipe size is a reflection of the engine power so the more power then the bigger those pipes need to be. Most stuff you see at the drag strip is 600HP or less and a 2 1/2 to 3" pipe is right for that.
A longer pipe also helps your low end torque as compared to an open header. What NAB said is correct and most drag cars vent the exhaust before the axle or out the sides so they don't face the restriction of the bends needed to go over the axle. Those bends add a lot of restriction over the normal straight pipes or open headers.
I bet I'm the only fast car that runs a full exhaust over the axle to the back bumper with mufflers on every pass, no open pipes or headers. I have blown pieces out the 4" dual exhaust so that tells you how much pressure is there and why no one does this in drag racing. I only do it because it's one more thing that makes this car different than what you are going to normally see but it's not the best way to do things.
So a smaller right size pipe will make you faster than a pipe too large as that will push your power band way up or beyond your RPM range. 2 1/2 or 3" is right for most cars and why you see it so much.
LTX Aluminum LT1 block engine
Most HP from an OBD1, 1900 plus horse power
Only TH400 with lockup and shifts from factory GM computer
Fastest Impala with everything still in it, 4520 pounds no weight taken out. ? in the ? MPH
Jeff Green is offline
post #5 of 13 (permalink) Old 04-03-2012, 11:53 AM
ISSF Honey Badger
Big Kahuna's Avatar
Send a message via AIM to Big Kahuna
The what now?
SAVE THE DATE: 2017 ISSCA NATIONALS in INDY July 26-30!!! You don't want to miss this one! Time to sign up! Go to:http://issca.org
*BEST of ISSCA 2005 & 2013 * ECIRS CHAMP 2004, 2006, 2012, & 2014 * ISSCA Spirit of Chino 2012 * SSHS '10 Class A Champ in Eriks TBSS
* 19 ECIRS (East Coast Impala Racing Series) event wins * Bunch of other stuff blah blah* www.ecirs.net - come race with us...if you dare!
-94 BBB: Big Block RamJet 502 - SOLD 2014!
-95 BBB: Brickyard 400 Pace Car aka Chino SS
-95 BBB: The one and only Flambe SS396 - 4600+ lbs of fun - Original Owner 2-21-95 - HOLY SH1T - 149K miles
........11.72 at 115 baby shot / 12.23 at 111NA
-96 BBB: Cliff's clean, perfect, 38K mile car - SOLD 2008 - wrecked by Cracka
- 96 BBB: SSato's Supercharged Best of ISSCA winner - 31K miles - SOLD 2006 - wrecked by Shane
- Cracka: "BK at a sushi restaurant....more devastating to the ocean than a BP oil spill...."
Big Kahuna is offline
post #6 of 13 (permalink) Old 04-03-2012, 12:05 PM
ISSF Honey Badger
Big Kahuna's Avatar
BTW Dan from Clear Image will tell you himself - the BEST way to make more power is to taper the exhaust as you go. In other words 3-4" up near the engine and then taper to 2 1/2" at the end. But of course anyone who wants to look good as well as go good wants bigger tailpipes.
Dan made these one-off for me but now I'm pretty sure he produces them for anyone that wants them. The polished part continues all the way up over the axle so it looks good between the rear tires and the wheel well where on every other exhaust system except the original Flowmaster you could see the break in the pieces of pipe fitted together.
As Uncle Pauly says..."Anyone can go fast. Anyone can look good. But there's very few people that can go fast AND look good!"
Jeff Green is one of them, his car is spotless clean. So is Uncle Pauly, Pat Gish, and Mikey Harris among others.
post #7 of 13 (permalink) Old 04-03-2012, 04:17 PM
angelo's Avatar
This is a point worth repeating... Air temp at the header is WAY hotter than air temp at the tail pipe.
Hot air moves fast, and cold air moves slow...with that logic, the exhaust pipe diameter from engine to bumper should be SHRINKING....not getting bigger.
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #8 of 13 (permalink) Old 04-03-2012, 05:36 PM
Boilermaker's Avatar
Crime Scene, ya done good. Ya gave BK (The Exhibitionist) a reason to show off his pipes, again.
Gene Zebley, aka "The Boilermaker", "Godfather" INC for Life GOD BLESS GEORGIA!
1996 ImpalaSS, Black Sunshine (Driving while knocking out the last items on the punch list)
Boilermaker is offline
post #9 of 13 (permalink) Old 04-03-2012, 05:38 PM
I'm partial to brushed stainless. Takes five seconds to clean after racing with a 3M pad.
post #10 of 13 (permalink) Old 04-03-2012, 09:30 PM
ISSF Honey Badger
Big Kahuna's Avatar
Look who's talking. Keep posting the same pics of your busted ass car that ain't moved in 4 years on FB. Thx.
