1981 Caprice Race Build (9/8/12 Count-down) - Page 9 - Chevy Impala SS Forum
post #81 of 152 (permalink) Old 01-31-2013, 04:55 PM Thread Starter
Haha thats too funny.
When I worked for Scion when the brand first hit the scene and ScionLife.com was blowing up I ran into that a LOT between building my own turbo car, and all the demos for the region (not so much in this community, but I also don't make the events very often).
bfurches is offline
post #82 of 152 (permalink) Old 02-04-2013, 06:46 PM Thread Starter
Started stripping the body today for paint
Honestly not looking forward to this portion of the project.
I have an aluminum hood from a Delta that I am going to mold into the header panel (it is roughly 1.5" longer then my caprice hood), I am deleting the all the stainless rocker moldings and wheel arches...only stainless I am keeping is the trim around the glass.
I am leaving all the body prep up to my brothers friend, and then hopefully his father can put some color on it for me.
....oh btw...added a new ride to the collection LOL
Last month my Fiances car got hit by an 18 wheeler (01 Monte SS), so I replaced it with this 05 Impala. Scored for 800.00!
bfurches is offline
post #83 of 152 (permalink) Old 02-25-2013, 09:43 PM Thread Starter
Here are a few photos of the newest part I machined up for my turd...
I have no clue if I am going to pursue this or not, but it is in the works LOL
bfurches is offline
post #84 of 152 (permalink) Old 02-27-2013, 07:32 AM
Blue Wail's Avatar
What is it?
Blue Wail is online now
post #85 of 152 (permalink) Old 02-27-2013, 10:06 AM
Toms9C1's Avatar
How did I miss this Brandon? Very cool mods to say the least! Are you going to NSHS2?
Tom
ISSCA Member #2540
95 B4U: LT4 LE Cam 1.6 RR Eibachs 17" SS Whls K&N XPypes Mech fan delete+Gary's wiring harness RM Lthr seats Imp SS Rear Disc Eaton Posi Motive 3:73's Moser Axles Stainless brake lines NEW 4L60E/Dacco 2000
94 9C1: Eaton Posi 3:73's XPypes Stainless Brake lines
95 L99 DCM: SS Clone Vogtland springs Monroe SS shocks XPypes Front end overhaul w/Alum bushings
96 RMW Woody Black / Red guts
96 RMS
http://badass-of-ne.forumotion.com/forum.htm
Toms9C1 is offline
post #86 of 152 (permalink) Old 02-27-2013, 01:15 PM Thread Starter
Originally Posted by Blue Wail View Post
What is it?
That is the male portion I machined of a coupler to run dual lsx engines in one chassis. It is a hardened 48 spline shaft that is pressed into an lsx crank spacer. Its all machined to ride in place of the converter pilot.
I finished the other side last night, I will post photos a little later.
bfurches is offline
post #87 of 152 (permalink) Old 02-27-2013, 01:20 PM Thread Starter
I'm going to try and make it!
bfurches is offline
post #88 of 152 (permalink) Old 02-27-2013, 01:55 PM
LeadSSled's Avatar
Is it April 1st already?
That sounds like an ambitious project. What chassis have you chosen that will give you enough longitudinal real estate to fit dual LSXs crankshaft-to-crankshaft?
1996 DCM SS, ISSCA #1170
SSled now with ERE#4: 385 stroker with LE3 cam and LE-ported Trick Flow heads.
12.383 @ 109.2 mph, 4350 lbs. race weight at SSHS6 (all motor)
11.895 @ 116.7 mph, 4415 lbs. race weight at SSHS9 (125-shot)
SSHS8 Bracket C Champion
2011 ISSCA Road Race Champion, Race class
2011 ISSCA Autocross Champion, Race class
I drive a hybrid - it burns both gas and rubber.
Waterford Hills Road Course: http://www.youtube.com/watch?v=qXmeEosQLjw
LeadSSled is offline
post #89 of 152 (permalink) Old 02-27-2013, 03:38 PM Thread Starter
I would like to put the setup in my Caprice. The LSX engines are extremely compact, and when you factor in how far back I moved the motor when I plated it....I actually have enough nose room in install a second. I would need to remove the radiator support and bend up a tubular unit that hugs the header panel, but I have taken quite a few measurements and I have the real estate under the hood to work with.
Here is the female side of the coupler. I machined the center crank hub off a truck dampener and machined a press-fit step into the female splines. It still needs to be finish welded on the flange before I can key it back in the lathe to make my final clean-up pass, but you get the idea...
Assembled unit...
__________________________________________________ ______
And just to give you an idea of how short these engines are and the room I will have to work:
bfurches is offline
post #90 of 152 (permalink) Old 02-27-2013, 06:48 PM
LeadSSled's Avatar
That would certainly be VERY cool. I don't suppose that you will have this combo ready for NSHS2 though.
