Cecil County Ice Cold Record Run Drag Day Dec. 8, 2012 - Page 4 - Chevy Impala SS Forum
post #31 of 169 (permalink) Old 11-26-2012, 10:20 PM
RatSSled's Avatar
Originally Posted by Dan Fahey View Post
For now got the bragging rights out of the car I wanted.
That is cracking the 12's with a essentially a 4320# BoltON.
I am right in there with Pat and Glenn.
Except I drove mine to the track !!
Do that Pat GISH
Dan
I don't know about Pat (he always came the 300?+ miles east), but I ran consistent 12.7's at full weight through full exhaust, incl. cats.
Good thing you're not coming. Get some rest, and avoid the embarrassment of getting blown away by a bolt-ons car with a 4l80e and 3.73's.
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
RatSSled is offline
post #32 of 169 (permalink) Old 11-27-2012, 05:04 AM Thread Starter
Blue Wail's Avatar
We will all peer check our bottles to be off. Alex can even use the nitrous that stays in his line if he wants cuz its just gonna bog with fuel after about .1 sec !!
Nab
Blue Wail is offline
post #33 of 169 (permalink) Old 11-27-2012, 06:37 AM
The Bolt-On Terror's Avatar
Make that 600 miles .
I drove mine to closer tracks too. It ran 12's any day of the year over here through the mufflers at full weight. 12.4-12.5 in good air uncorked at 1000'.
Those 12.3's at Cecil were not in it's final bolt-on glory nor in spectacular Cecil air.
You're not in "Pat and Glen" territory yet, Dan
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #34 of 169 (permalink) Old 11-27-2012, 07:04 AM
LeadSSled's Avatar
Do that Pat GISH
Dan
[Lloyd Bentson]
Driver, I raced with Pat Gish. I know Pat Gish. Pat Gish is a friend of mine. Dan, you're no Pat Gish.
[/Lloyd Bentson]
1996 DCM SS, ISSCA #1170
SSled now with ERE#4: 385 stroker with LE3 cam and LE-ported Trick Flow heads.
12.383 @ 109.2 mph, 4350 lbs. race weight at SSHS6 (all motor)
11.895 @ 116.7 mph, 4415 lbs. race weight at SSHS9 (125-shot)
SSHS8 Bracket C Champion
2011 ISSCA Road Race Champion, Race class
2011 ISSCA Autocross Champion, Race class
I drive a hybrid - it burns both gas and rubber.
Waterford Hills Road Course: http://www.youtube.com/watch?v=qXmeEosQLjw
LeadSSled is offline
post #35 of 169 (permalink) Old 11-27-2012, 11:20 AM
Dan Fahey's Avatar
Yeah your car rocks!
BUT what does full weight mean Stumpy ??
Believe your car was 300# lighter than mine at 4000#.
I know Pats was around 3800#.
My cars configuration weighed in 4310# and by IHRA Tech.
Figure at 4000#, F/PS weight, the car could have hit a 12.5x.
Wish I could come but need to rest this Nerve.
Dan
Dan Fahey is offline
post #36 of 169 (permalink) Old 11-27-2012, 11:21 AM
Dan Fahey's Avatar
Originally Posted by LeadSSled View Post
[Lloyd Bentson]
[/Lloyd Bentson]
I KNOW !!!
PAT KISH is NO DAN FAHEY either..
However he is a Brother from another Mother !!
Dan
post #37 of 169 (permalink) Old 11-27-2012, 11:36 AM
oooohhhh, Dan! you're getting ball-busted from all directions
you're running a race cam, Dan. Hell, I'd have gone 11's with THAT!
Oh, and my car was 3925 back then Come on, Dan, read!
.Oh, your car IS running damn good for its weight, no matter what your cam specs are
NA: 10.98 @ 122
post #38 of 169 (permalink) Old 11-27-2012, 11:59 AM
Moby Dick's Avatar
Send a message via AIM to Moby Dick Send a message via Yahoo to Moby Dick
Poor Dan....12.60 with 3.73's driven to the track for my HOBO. Add the stock cam. GWS my friend.
Good luck to all this weekend and let's post up all the new PB's. Moby Dick Motorsports will be staying south on this one.
Eric Seaman
1994 Caprice Wagon "Moby Dick"
1996 Impala SS 383 11.604@117 CC503 with 3.73's.
1.52 60' on drag radials
"Fastest NA 383 3.73 equipped car on the board"
ISSCA Member #2517
Moby Dick is offline
post #39 of 169 (permalink) Old 11-27-2012, 02:36 PM
Dan Fahey's Avatar
Thanks Pat..
Thought I would offer some comic relief over ALEX
Btw the PS CAM is no RACE CAM and idles at 650rpm.
It has to meet Duration, Overlap and Lift of an F-body cam using the Stock Stamped Rockers.
Damn near same specs as a B-Body with 1.6RR's.
The only difference, the PS Cam is ground at 110LSA a B-Body is 111LSA.
Not much difference, in fact the shift points are identical to my Hobo set up.
There maybe a 10 hp improvement but that is about it.
Getting back to comparisons.
Your car is more than 375# lighter than mine, huge !!
AND ole Stumpy's was about the same weight too...
That is worth about 4 tenths ...so I am in the ball park !
AND have all the assessories operating and running through Cats and Mufflers.
However if the cam is replaced with a real Stocker cam.
The car would be running mid to high 11's at 4355 #.
AND I would have to have a ROLL BAR !!
I would brag that I have the fastest ECIRS G/PS car.
But Southern Racer Corbitt Marshburn holds that notoriety.
So I cannot win, lol !!
Right now keeping it as is. But If trailered I would move up to F/PS.
Remove the power steering and AC, add more converter, gear and tire.
As is there is a bit more left in it such as a Dyno Tune, weigh shifting.
A Mike Harris crossmember is on next years shopping list.
Dan
post #40 of 169 (permalink) Old 11-27-2012, 03:44 PM
RatSSled's Avatar
Dan
Back when I first took the class 6 record with a 12.74 at 104 I had no clue about weight reduction. I was running DR's in the back and pretty much everything that came with the car and then some. Ever compare the weight of a HA rear bar to a stock sway bar? I estimate that the weight was about 4,350 lbs with me in it that day.
Celeste currently has the 2nd fastest class 6 time at ~4,000 lbs race weight. With me at the wheel it's closer to 4,100 lbs, or slightly less depending on what I took off the car. Celeste may have taken the record had she been willing to pull the belt that day. Where is Nab when you need him?
RatSSled is offline
