Race wheel questions - Chevy Impala SS Forum
post #1 of 39 (permalink) Old 02-14-2013, 01:00 PM Thread Starter
subssonicimpalass's Avatar
I'm looking at buying some drag racing wheels. What kinda backspacing do I need? Also is 10" wide a good width to go with?
Here is one of the wheels I was thinking about. Trying to keep the price down.
http://www.summitracing.com/parts/sum-85-5173/overview/
What do you guys think?
Do you guys have suggestions for tires?
'95 DCM Impala SS 125,000 miles
Jax INC
CAI, no cats, 2.5" exhaust with flowmasters and H pipe, 4:10 gears, Eaton posi, PCMFORLESS tune, airpump delete, bonnies, lowered on 22"s, tinted tails, GEN 2 Tri-y's, extended upper and lower rear control arms, Yank SS3600
Supercharged stroker underway!!
subssonicimpalass is offline
post #2 of 39 (permalink) Old 02-14-2013, 01:06 PM
I'd send a PM to Mike Harris (1FAST94) he has studied this subject exhaustively,and I'm sure he would share his recommendations with you.
post #3 of 39 (permalink) Old 02-14-2013, 01:16 PM
Barbarossa's Avatar
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
Then please post up what Mike tells you!
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
Barbarossa is offline
post #4 of 39 (permalink) Old 02-14-2013, 01:56 PM
1FAST94's Avatar
I got your PM. Try to stay with factory wheel offset to keep the tire under the car. For 8" wheels, a 4" backspacing will work and is popular. For 10" wheels you need a 6 1/2" backspacing, but 6" would work. If you run 10" wheels you'll have to be careful what tire you use so as not to rub inside and may need some thin wheel spacers. I have notched my framerails and use a 10" wheel with 6 1/2" back spacing and can run whatever tire I want. Pat Gish uses a 10" wheel with the same offset with a smaller tire ans stock framerails.
Mike Harris
B-BODY PERFORMANCE
Dayton, Ohio
10.43 @126.95 @ 3800 lbs.
http://www.youtube.com/watch?feature...&v=a8dYCl2cAdM
1FAST94 is offline
post #5 of 39 (permalink) Old 02-14-2013, 02:15 PM Thread Starter
Thanks for the reply. If I go with the 10" with 6" backspacing, how wide of a tire can I go and be safe? (no rub)
Jax INC
post #6 of 39 (permalink) Old 02-14-2013, 05:58 PM
Lightbulb
I run 15x10 Holeshot Holestar's with a 6" BS, and 28x10 Hoosier slicks, and they fit just fine.YMMV This is with non-centered axles, and stock ride height.
SSeeya,
Bob Dannelley
95 409-DCM-11.839@115.10-NA,4350#
2011 Caprice PPV-Maggie-11.64 @ 119.68
2014 LTZ Crewcab 4x4-my fu k k in' present to me!!
Leadfoot is offline
post #7 of 39 (permalink) Old 02-17-2013, 12:57 PM
Lance's Avatar
If you can not afford aluminum lightweight wheels these are a nice alternative starting at $79: Bassett D-Hole Lightweight steel wheel
15x8 with 4" backing spacing weighing 17lbs each.
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
12.32 @ 109, ESE 357, LE2 heads, LE 224/230
12.86 @ 105, Reman 355, Z28 heads, CC 502, CPT 3, Edge 3400, 4.10, PCM4Less
96 SS:
11.74 @ 117, ERE 383, LE2 heads, AI 234/242, CPT 3, Yank 3600, 3.73, PCM4Less
12.28 @ 110, Golen 383, LE2 heads, CC 503, CPT 3, Yank 3600, 3.73, PCM4Less
13.07 @ 101, Rebuilt LT1, LE2 heads, Crane 227, CPT 3, Yank 3600, 3.73, PCM4Less
14.11 @ 95, Stock LT1, Edge 3000, 3.73, PCM4Less
Lance is offline
post #8 of 39 (permalink) Old 02-17-2013, 03:08 PM
Do you think these would be strong enough for a daily driver?
ssimpala is offline
post #9 of 39 (permalink) Old 02-17-2013, 06:02 PM
Lance's Avatar
I bought the Bassett Armor Edge wheels that are DOT and 19 lbs for 15x8s.
The wheels require 45 degree conical lug nuts.
Check out these lightweight aluminum lug nuts.
Lance is offline
post #10 of 39 (permalink) Old 02-22-2013, 06:21 PM
The Lazy Destroyer's Avatar
What do something like the 15x10 Holeshot Hole Stars weight in at?
-Blake
________Motoception Photography________
"Those who possess power define those who are powerless."
95 Caprice 9C1, 12.9 @ 103 mph, 1.74 60' - Bolt-ons car
96 Caprice Wagon - "Nomad SS"
94 RMW woody
The Lazy Destroyer is offline
