Front End Suspension Kit - Chevy Impala SS Forum
post #1 of 23 (permalink) Old 08-25-2016, 06:09 PM Thread Starter
supersporty's Avatar
I hear that theres complete front end kits, that can be purchased, and I need 2 sets ! I have a 94 SS and a 96 Roadmaster, and both need front end work, so while I am at it, i want to take care of it all...
Can anyone recommend a front end kit?? and where to purchase ??
Thanks
supersporty is offline
post #2 of 23 (permalink) Old 08-25-2016, 10:23 PM
Far as I know both ProForged,and Hotchkis still offer complete kits. Kinda depends on what "complete" means to you. Not sure if ball joints,and/or control arm bushing are included in either kit...
quickest event reaction time .017sec. (final-round)
post #3 of 23 (permalink) Old 08-26-2016, 08:15 AM
You can get the parts from Rock auto. They sell complete upper and lower arms to bolt on, including the ball joints. I believe they have them in Moog, and house brands. The other parts can be purchased individually as well. It is a pretty simple list. Rock Auto may even have kits for the steering.
It is a lot easier to R&R the upper arms if you remove the studs, and reinstall them after placing the arms. You can use a standard nut instead of the pinched nut to draw the studs into the frame.
A full alignment is necessary after replacing the arms, not just a toe and go.
Fred Kiehl is online now
post #4 of 23 (permalink) Old 08-26-2016, 11:34 AM
Most gratifying tightening up effect from the additive impact of replacing everything at the same time. Fred's right - all the micro-measuring you try matching link dimensions won't save anyone from a "legitimate" alignment; something only specialist shops still do. Budget 2+ hours and min. $150. I found a kit from an old forum supporter for about $25 cheaper than piecing it up myself, which was easier before online ordering became so painless. All the stoutest Moog Troubleshooter stuff thank you very much.
post #5 of 23 (permalink) Old 08-26-2016, 12:41 PM
juniorwatson's Avatar
Originally Posted by 96 Black View Post
[SNIP]
Is that the tail end of an 80's Monte Carlo I see there?? I always liked them back in the day.
Clear Image Tri-Ys & Hi-Flow cats to CIA 2.5" X-Pipe & Spintech Mufflers, Mike Harris 4L60E, Vigilante 3,400 RPM Converter, MOOG FT end, Del-A-Lum bushings in new MOOG CTRL Arms, Eibach FT Springs, New Stock rears. Hotchkis Sway Bars & End Links, RAISS, Dynoshaft, CIA Driveshaft Loop, BMR Trailing Arms, Braided Brake Hoses, Taylor Spiro-Pro Wires, AutoMeter 2-5/8" Water Temp & Oil PSI Gauges, Impala Console. ATE Blue Brake Fluid. Skip White distributor. Newly Installed 20's on 1/1/2017
juniorwatson is offline
post #6 of 23 (permalink) Old 08-26-2016, 03:04 PM
You can get a camber/caster gauge on ebay for $60, and up.
Snap on WA40 Magnetic Caster Camber Gauge | eBay
78260 78260 Longacre Magnetic Caster Camber Gauge | eBay
Make sure you get the magnetic adapter, or the 3/4-20 Chevy adapter.
The cheapest ones do not use a valid attachment point. The disk rotor will be less than flat, and not a good reference point for alignment purposes.
If you use it once, you have paid for it, and then some. If you use it a second time, it is a free alignment. You can also determine how much caster you want (up to the limits of adjustment).
post #7 of 23 (permalink) Old 08-26-2016, 05:34 PM
Yep, '88 Monte SS. It's going up the block soon.
post #8 of 23 (permalink) Old 08-26-2016, 08:43 PM
You really can't go wrong with Moog or Proforged parts. Stay away from the Duralast, etc parts or any of those cheap kits you see on eBay....they're just that, CHEAP! Both are really stout parts. As someone else asked....what do you consider a complete rebuild? Some just do the hard parts....BJ's, tie rods, end links, etc. but if you're looking to do the entire front, this may also include bushings as well.
You have some options there too, go with poly bushings or stick with stock. If you decide to keep your original arms, you can borrow all the tools you need from AZ or whoever loans tools and save yourself some money. The other option is get the arms already loaded or take your arms to a shop and have the parts removed and pressed in.
There are many threads on how to replace things if you DIY. Be sure to get the car aligned and if you remove the upper arms, be sure to get new nuts that secure the upper arms to the frame and don't reuse the originals. They lose their effectiveness to hold and you could lose shims or worse.
post #9 of 23 (permalink) Old 08-27-2016, 09:54 AM Thread Starter
I found that ebay had the best prices as well. The parts on my list I was going to replace were.....
2 lower ball joints
2 end links
1 billet adjuster
2 tie rod ends
1 idler arm
2 inner tie rod ends
2 upper ball joints
On ebay I found Pro Forged parts, and all of them totaled just under $290. I was also going to pick up ZQ8 bumpstops... The only ones I find are the Doormans. Anyone got any experience with the doormans ??? Dont wanna have to pay for them if theyre not worth it ... I already got a **** ton of money to spend .....
post #10 of 23 (permalink) Old 08-27-2016, 10:17 AM
If you are not lowering the car the ZQ8 bump stops are not necessary.
