Alignment specs for best tire wear - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 09-11-2009, 12:55 PM Thread Starter
I totally rebuilt the front end on my '91 Caprice wagon and it drives like a new car, but the knuckleheads that did the front end alignment did a crappy job that I didn't catch at first.
They left the right front at 1 degree of positive camber, which is right on the edge of out of spec and its causing excess wear on the outside edge of the tire.
I'm going to have it re-aligned but I want to get it right this time.
Does anyone know what the best alignment specs are for best tire wear, its a totally stock car with stock size tires, so I'm after best tire wear, not performance.
Thanks,
Paul T.
titchener is offline
post #2 of 5 (permalink) Old 09-11-2009, 04:10 PM
JonRobbinSS's Avatar
For good tire wear and nice driving I like;
Camber -0.5 degree +/- 0.25
Caster (as much as they can get) 4.5
Toe 0.06 or 0.12 total (1/16 inch toe in or 1/8in total)
If you have lots of road crown in your area a normal amount of cross caster can help. A good alignment guy will know how much is required for your area.
hope this helps
SOLD - 95 DCM - ERE#3 (383)
NEW CAR - 2009 Pontiac G8 GXP M6
Member ISSCA, Cali-SS, ISSOAH, TRIC
JonRobbinSS is offline
post #3 of 5 (permalink) Old 09-11-2009, 09:15 PM Thread Starter
Thanks for the help Jon. I think my biggest problem is finding a good alignment guy, nobody seems to give a crap about their work around here, but I guess their bosses are pushing them to finish every job in 10 minutes, what the hell can you do.
Paul T.
post #4 of 5 (permalink) Old 09-11-2009, 11:47 PM
I had my car set up to these specs, http://www.sofasst.com/tech/alignment.htm. Drives nice and no abnormal tire wear noticed.
95 DCM SS
2011 Silverado CC 6.2L Z71
Egghaus is offline
post #5 of 5 (permalink) Old 09-12-2009, 12:36 AM
Scott Knight's Avatar
Isn't it that way with anything any more? Sorry, I don't have any tips for procuring good service. I 'solved' the dilemma by doing my own alignments. To wit, I am more motivated than most, since I like to experiment and need multiple setups. For me to buy the equipment cost less than 1 year's worth of bad alignments. Your mileage may vary
The most elaborate piece of equipment you need is going to be the camber/caster guage and some kind of fixture to mount it on your wheel. This is what I splurged on:
The rest of the equipment pretty much consists of a dozen of those solid cinder blocks, 4 pieces of vinyl tile, some string and a couple of jackstands. Here is my car on my 'alignment rack':
I don't do it exactly like this guy, but his writeup is the best I have ever seen (hint: print it to a PDF for safe keeping because I am surprised it's still a working link):
http://home.comcast.net/~jkrane/susp...y/susp401.html
Scott Knight
1994 Impala SS (finally under construction)
1995 9C1 6-speed (put back to stock and sold)
1995 9C1 (sitting abandoned since 2002, likely waiting to be crushed sometime in the future)
"If my answers scare you, then you should cease asking scary questions"
Scott Knight is offline
