steering shaft - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 11-28-2009, 10:45 PM Thread Starter
slackskillz's Avatar
steering shaft
So, I finally came up on a steering shaft at the junkyard... was easier to get out than i thought it would be... cant wait to get it in... but that brings me to my question...
how do I get it to collapse? should i do some persuasion with a rubber mallet? once I get it collapsed i assume it will collapse far enough to not have to take the whole steering column out?
thanks
daren
slackskillz is offline
post #2 of 11 (permalink) Old 11-29-2009, 12:54 AM
I was fortunate enough to have collapsed mine in the process of removing it. Soak it for a night or more in your favorite penetrating fluid (not wd40). Put it in a vise, or clamp it to something sturdy and tap around the joint. Be cautious about hitting the ujoint. Be patient and it will work loose, brake fluid mixed with acetone is my weapon.
95 Caprice L99
"..At the worst, if he fails, at least he fails while daring greatly.."
TEDDY ROOSEVELT
Mista M is offline
post #3 of 11 (permalink) Old 11-29-2009, 01:05 AM Thread Starter
I have it soaking in oil right now..that should be alright, yeah? figured that'd get it loose by morning
post #4 of 11 (permalink) Old 11-29-2009, 01:31 AM
I know all the old heads i hang with say motor oil or brake fluid to loosen bolts. Should work, if it doesn't BFH
95 Caprice L99
TEDDY ROOSEVELT
Mista M is offline
post #5 of 11 (permalink) Old 11-29-2009, 06:34 AM
wytltng's Avatar
PB Blaster is better. When you get it moving grease it up. That thing should slide back an forth real easy when you are done. It should move easily w/hand pressure.
wytltng is offline
post #6 of 11 (permalink) Old 11-29-2009, 06:57 AM
I'm missing something here................why do you want to callaspe?
God Bless America!
1996 Impala SS DCM
1996 Impala SS BBB
1995 Buick Roadmaster Sedan
2014 Chevrolet VOLT
2016 Chevrolet Cruze
1986 Corvette Coupe
1988 Lincoln Mark VII LSC
1986 Ford F250 6.9 Diesel 4x4
Mikeceli is offline
post #7 of 11 (permalink) Old 11-29-2009, 08:31 AM Thread Starter
It's longer than the stock steering shaft... collapsing it will make it work with our cars.
post #8 of 11 (permalink) Old 11-29-2009, 09:12 AM
Freedog's Avatar
Send a message via Yahoo to Freedog
I used WD40 and a BFH. It was a job but I got it done. DON'T hammer or otherwise stress the joint. This mod made an improvement but I have to come to terms with the fact that a 96 RMW wont ever steer like a car with rack and pinion. My next and last mod in regards to steering is the Trans Am steering box I have in the garage. I can get a rebuild kit at work for cheap but judging by what i've read, there isn't much to rebuild. More to come.
Ruphrax sourced 1996 RMW
Caddy tail lights
2.5" catback w/flowmaster 40's, X-pipe, & 911 tips
Ram Air hood/intake
Smooth front bumper
Rear roll pan
Rear wiper delete
Custom SS grill
UMI LCA's
Electric fan conversion
Hotchkis rear sway bar
Eagle 20's
Bonnies
Intrax springs
Bilsteins
160 thermostat
Soon to come: Reflash, 1.6 rockers, gears, custom console, bags, custom sub enclosure, HUD, 19" LCD monitor in tailgate, Trans Am steering box,
http://www.cardomain.com/ride/3140885
Freedog is offline
post #9 of 11 (permalink) Old 11-29-2009, 10:39 AM
wytltng's Avatar
Those steering shafts are made to collapse on impact. Saves the frame and from keeping the steering column from impacting your chest.
You would be surprised on how seized they get over the years.
wytltng is offline
post #10 of 11 (permalink) Old 11-29-2009, 11:14 AM Thread Starter
do our stock shafts collapse easily? I'd hate to have to take out the steering column.
