Removing front control arm bushing? - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 03-23-2010, 08:10 PM Thread Starter
fuzzcar's Avatar
Im trying to get these out. I tried burning the rubber out on one of them but the outter sleeve does not want to give.
fuzzcar is offline
post #2 of 11 (permalink) Old 03-23-2010, 08:18 PM
HuSSker's Avatar
Most people drill/cut the rubber out of the old bushing, and then cave in the sleeve through whatever means you prefer, without damaging the control arm.
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
post #3 of 11 (permalink) Old 03-23-2010, 08:24 PM Thread Starter
fuzzcar's Avatar
How well do the tools made for it work? My ball joint press is just a little too big to do it.
fuzzcar is offline
post #4 of 11 (permalink) Old 03-24-2010, 01:31 AM
Navy Lifer's Avatar
You talking upper or lower?
Lower can be removed with a properly-sized hammer/sledge, applied at the correct angle on the INNER lip of the bushing shell. The control arm is placed on it's side on a suitable supporting surface--work bench, large block of wood, etc, with the bushing "cantilevered" over the edge/end of whatever surface you're using--so there's room under the arm for the shell to move out of position. Hold the arm with one hand, and strike the bushing shell correctly and it will pop loose from the arm with no other effort.
TRUST ME, I've done enough of these.
Yes, corrosion and age can be issues.....and unless you're talking about uppers, that's how I have done it for quite a long time--and successfully. It is NOT how the book says to do it, I will admit....and the proper way to install new bushings is still using a press/tool of one type or another.
Uppers are more involved, so please say which you're having problems with.
Bill Harper
ISSCA #127
inov8r@windstream.net
Navy Lifer is offline
post #5 of 11 (permalink) Old 03-24-2010, 04:58 AM Thread Starter
fuzzcar's Avatar
Lowers, I havent even tried the uppers yet.
fuzzcar is offline
post #6 of 11 (permalink) Old 03-24-2010, 02:36 PM
I have done the uppers the same way for years. A good air hammer with chisel works wonders. Walks even the most rusted bushings right out. It will beat up your body real well though.
Terry
2 1995 9C1s
30U Huet Silver Metallic built 5/26/95
36U Bonnat Silver Metallic built 7/19/95
1 1995 1A2
2001 Camaro B4C SOB -- one of 288
2008 Z06 Jetstream Blue built 10/11/07
Terry #585 is offline
post #7 of 11 (permalink) Old 04-09-2010, 07:57 PM Thread Starter
fuzzcar's Avatar
Well guys it was a bear getting mine out. I used a torch to burn the rubber out and had to use a dremel to cut notches in the bushing shell then alot of beating and cussing.
The Kent Moore tool for doing it is $800! My ball joint press wouldnt work I didnt have the right adaptor cups.
fuzzcar is offline
post #8 of 11 (permalink) Old 04-09-2010, 09:01 PM
wytltng's Avatar
Here is a tip when doing the uppers.
Remove one busing & then you can remove the shaft, then the second bushing.
Reverse to install.
wytltng is offline
post #9 of 11 (permalink) Old 04-09-2010, 09:03 PM Thread Starter
fuzzcar's Avatar
I used this tool on the uppers and it was a piece of cake!
http://www.amazon.com/gp/product/B00170UTYY/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0028QGT90&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=05EGWFXQ562E944B8FTC
fuzzcar is offline
post #10 of 11 (permalink) Old 04-09-2010, 09:06 PM
wytltng's Avatar
I always install the rear bushing first due to it sitting more flush in the arm.
wytltng is offline
