steering lock up!!!! - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 03-18-2011, 10:08 AM Thread Starter
TravisIA96's Avatar
hey all. I hhave a problem with my 96 ss. If I sit and try to turn the wheel it creaks and groans and studders and stops and sometimes just locks up. Only does it at a stand still. Driving is perfect. Very responsive. I've checked the ps fluid and put condisioner in it. I don't know what to do... thanks!
1996 Black Impala SS. Cold air intake, edelbrock shocks, 7in flip out DVD. Blue led interior swap in the works, Blue bowtie, blue calipers with silver impala ss vinyls. blacking out in progress!
TravisIA96 is offline
post #2 of 5 (permalink) Old 03-18-2011, 10:59 AM
Check your water pump and see if its leaking on the belt. A failing water pump will leak water out of the weep hole on the bottom and it will cause the belt to slip.
2005 Pontiac GTO
cletus284 is offline
post #3 of 5 (permalink) Old 03-18-2011, 11:01 AM Thread Starter
TravisIA96's Avatar
I will check that out. I hope that would be that and not something major. Would a slipping belt cause nasty screechy noises and lock ups?
post #4 of 5 (permalink) Old 03-18-2011, 11:36 AM
You might be luckier having the screechy noise. A new belt, even a new WP, is still way easier than a PS pump replacement.
post #5 of 5 (permalink) Old 03-18-2011, 11:39 AM Thread Starter
TravisIA96's Avatar
Its a weird noice. Not like a belt slip screech but a metal noise...
