Timing retard on nitrous? - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 04-14-2012, 09:44 AM Thread Starter
Hi from SWEDEN.
I wonder what kind of retarder I use best to retard ignition when I use nitrous! I only want to retard ignition in one step.(5-9deegrees.)
I have MSD-opti and MSD 6AL BOX ON MY CAR.
Sincerly Frank.
Zappa is offline
post #2 of 12 (permalink) Old 11-04-2012, 10:59 PM
MSD makes a few options like a digital 6 ignition box which will let you do a single stage retard. or they also make a multi stage retard box.if I remember correct you need to retard the timming 4 degrees for every 50 HP of nitrous
djvez is offline
post #3 of 12 (permalink) Old 11-05-2012, 05:58 AM
The Bolt-On Terror's Avatar
Yes, the Digital 6 will give you the retard. However, if you're running anything over a 50-shot with a streetable torque converter, you should run a window switch, so I used the Mallory 685 box, which has a built-in window swtich.
And that's 4 degrees per 100 hp of nitrous.
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #4 of 12 (permalink) Old 11-05-2012, 11:16 AM
that mallory is a pretty nice unit.I was gonna upgrade from my 6AL to a digital 6.I have a vigilante 2800 stall in my 95 SS ,so would it be better to upgrade to the mallory?and also I have the MSD blaster coil how would that wire into the mallory or would I have to upgrade to a mallory coil and which one if you know off hand?
djvez is offline
post #5 of 12 (permalink) Old 11-05-2012, 01:19 PM
Since you're already running an MSD box, I assume you have their harness that adapts to the coil plug. If so, the Mallory box will be a direct plug-in replacement for the MSD box. I used the MSD adapter harness with the Mallory box.
NA: 10.98 @ 122
post #6 of 12 (permalink) Old 11-05-2012, 05:00 PM
very cool,yea i got the plug.thanks for the info and I hope this answered all of zappas questions lol.
djvez is offline
post #7 of 12 (permalink) Old 11-06-2012, 11:33 AM
GuillaumeC's Avatar
I use to have the Mallory 685 and loved it! It's not very expensive and does everything.
No need to buy "pill", everything is adjustable. Soft rev-limiter, 2-step, timing retard, window switch, etc.
Guillaume Charest
1995 DGGM Caprice, 355ci twin turbo, TH400, F.A.S.T. EFI, 4200 lbs street car 9.96 @ 141.2 mph **SOLD**
1989 Mazda RX7 Turbo II, 357ci LT1, AI 215cc heads, single plane, GTX4708R turbo, TH400, 8.8" SAS, Holley Dominator EFI
GuillaumeC is offline
post #8 of 12 (permalink) Old 04-21-2013, 07:23 PM
mallory box
anybody ot a part # for that ingnition box?? I see a few my 6a went out and plan on adding nos to my car.
rickeybobby9c1 is offline
post #9 of 12 (permalink) Old 04-22-2013, 05:56 AM
The part number is 685, like he said.
Here's the Summit link: http://www.summitracing.com/search?k...ry%20685&dds=1
NA: 10.98 @ 122
post #10 of 12 (permalink) Old 12-14-2015, 02:22 PM
is the mallory box not available anymore?im looking for it on summits site and nothing.
djvez is offline
