cc503 cam, rrs, and springs - Chevy Impala SS Forum
 1Likes
post #1 of 13 (permalink) Old 05-11-2017, 02:36 PM Thread Starter
Send a message via AIM to fast lt1
Ok, I've decided to go with the cc503 cam in my lt1. But with that comes a lot of things I don't know, so I need some help on other part selection. What I need to know, are the part numbers for the springs, RR's and Retainers
I know comp cams 915 or 918 springs are good. Not sure which I need. Or I heard some LS springs will work???
also not sure which RR's to go with
what retainers to use
what pushrods to use
and for lifters, just going to use stock gm ones from the dealer.
Thanks in advance
fast lt1 is offline
post #2 of 13 (permalink) Old 05-11-2017, 02:42 PM
Do you have iron or AL heads?
Comp 915 or 918 springs....IMHO neither but your head type (AL or iron) will determine a spring recommendation
If AL heads, Get the Lunati spring kit #73925K5
BALLSS is online now
post #3 of 13 (permalink) Old 05-11-2017, 02:43 PM Thread Starter
I am running cast iron heads. sorry
What would you run if not the cc springs
fast lt1 is offline
post #4 of 13 (permalink) Old 05-11-2017, 04:33 PM
for iron heads I would use the Crane 10309-1 spring kit
To many reports of spring failure on the Comp bee hives. Mine broke under 20k mi.....
The crane spring is good for .640 lift so even with 1:6 RR with the 503 cam you are good. They install same height as stock springs and you use your stock 7 degree locks with them.
Might want to replace your valve stem seals when you do springs. FelPro Viton you can get at most auto part stores
The Crane Gold "narrow body" 1:6 RR SA in the 3/8" (stock) stud size fit under the stock valve covers without any trimming. With that said the Comp Pro Mag, Ultra Pro Mag now, are a steel RR and considered stronger but you do need to do some minimal trimming of the braces inside the VC, no big deal. I have run the Crane RR though without issue on my iron head motor I am putting in another car
post #5 of 13 (permalink) Old 05-11-2017, 09:12 PM
Great cam. Love my car after doing the same. I did heads, stall, tranny, gears, exhaust, fuel, etc at the same time.
Bovineplane is offline
post #6 of 13 (permalink) Old 05-12-2017, 11:36 AM Thread Starter
Exactly what i'm doing now
Eaton Posi with Yukon 3.73 gears and new Yukon axles
ATK Trans W Yank stall converter and bigger cooler
walbro fuel pump and bigger injectors
Replacing my 488 comp cam with the 503 and going to 1.6rr from 1.5
fast lt1 is offline
post #7 of 13 (permalink) Old 05-12-2017, 07:17 PM
KW Baraka's Avatar
I would suggest you keep the 1.6 rockers......unless you broke/damaged one or more of them.
KW
KW Baraka is offline
post #8 of 13 (permalink) Old 05-13-2017, 11:23 AM
KW
Op says he is switching from 1:5 to "1:6" RR
post #9 of 13 (permalink) Old 05-13-2017, 11:31 AM
KW Baraka's Avatar
LOL......not paying close enough attention to what I was reading!
KW
post #10 of 13 (permalink) Old 05-15-2017, 01:23 PM
Send a message via AIM to FaSSt9602
Unless you have already gotten a smoking deal on the 503, I would suggest heading over to Lloyd Elliot at Elliot Port Works and have him spec a cam and springs based on your goals and what has been done to the car. The 503 historically hasn't been a bad cam, but there is room for improvement...
KW Baraka likes this.
1996 DGGM Impala SS
Project Resurrection 396 in the works!
FaSSt9602 is offline
