Ellwein Engines :) - Page 2 - Chevy Impala SS Forum
 5Likes
post #11 of 25 (permalink) Old 06-12-2017, 01:43 PM
KW Baraka's Avatar
Originally Posted by madamorr View Post
More progress.
I removed the motor from the shipping crate.......I installed the Opti.....
This would've been the perfect time for doing the TorqHead 24x conversion.
IJS.....
KW
KW Baraka is offline
post #12 of 25 (permalink) Old 06-12-2017, 03:39 PM
juniorwatson's Avatar
More progress.
I removed the motor from the shipping crate and put it on my engine stand.
I installed the Opti, WP, headers, misc brackets, plug wires and various sensors. Getting close to be able to stuff into the Impala.
What make are those plug wires? Unless it's an optical illusion, those wires look really huge from this perspective.
Two more questions:
1. In the last picture there is a piece of tubing going vertical right after the LH spark plug boots; what is it, a crankcase ventilation?
2. What's the pipe fitting tubing that's coming off the #1 cylinder header tube?
Thx!
Clear Image Tri-Ys & Hi-Flow cats to CIA 2.5" X-Pipe & Spintech Mufflers, Mike Harris 4L60E, Vigilante 3,400 RPM Converter, MOOG FT end, Del-A-Lum bushings in new MOOG CTRL Arms, Eibach FT Springs, New Stock rears. Hotchkis Sway Bars & End Links, RAISS, Dynoshaft, CIA Driveshaft Loop, BMR Trailing Arms, Braided Brake Hoses, Taylor Spiro-Pro Wires, AutoMeter 2-5/8" Water Temp & Oil PSI Gauges, Impala Console. ATE Blue Brake Fluid. Skip White distributor. Newly Installed 20's on 1/1/2017
juniorwatson is online now
post #13 of 25 (permalink) Old 06-12-2017, 04:06 PM
Originally Posted by juniorwatson View Post
Two more questions:
Thx!
that tube is for the air pump (emission).
The fittings on the headers are for the check valves that are part of the air pump system
post #14 of 25 (permalink) Old 06-19-2017, 12:42 PM Thread Starter
Those wires are big wires. I purchased the custom plug wires from Rustic racing many years ago. I am not sure about the physical size of the inner plug wire, but including the outer wrap, the wires are 13mm.
More photos as the engine and transmission are now in the Impala.
ID:	160530   Click image for larger version
ID:	160538   Click image for larger version
ID:	160546   Click image for larger version
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 in process with LE TFS heads.
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
post #15 of 25 (permalink) Old 06-19-2017, 02:06 PM
TGO
Why keep the air pump? They do sniff tests in Texas?
TGO is offline
post #16 of 25 (permalink) Old 06-19-2017, 03:12 PM
KW Baraka's Avatar
I believe they do in the Dallas and Houston areas.
KW
post #17 of 25 (permalink) Old 06-19-2017, 05:06 PM Thread Starter
Yes, unfortunately I have 1995 that has to pass the visual and pipe sniff test for a few more years. The setup that was specified for me was chosen to be able to pass the sniff test in the area where I live (DFW).
Michael
madamorr is offline
post #18 of 25 (permalink) Old 06-19-2017, 05:18 PM
P
Exactly what I was thinking. The removal of the Airpump won't affect your emissions but will fail the visual obviously. But you could still "disable" it as outlined in the TSB.
post #19 of 25 (permalink) Old 06-19-2017, 05:29 PM
Well if Madamorr emission testing is like here in Calif. you need to have air pump installed to pass visual.
It does not have to work "if" you have the "disable" sticker issued by GM
GM part # 12569123
In looking at the TSB the service labor only has PCM re-flash for 96 (OBD2). For 95 I believe you can just pull the relay without throwing the CEL on...which "disables" the air pump
GM didn't want to pay the labor to "remove" the pump and cap off the exhaust manifolds, just pull a relay and flash a PCM for 96 cars. It is the specific language in the TSB, and sticker, that says "disable"...not "remove"
The TSB is for:
95-96 RM, Cad Fleetwood, Caprice & Impala with 4.3 or 5.7 engines
post #20 of 25 (permalink) Old 06-19-2017, 11:37 PM
TGO
What do you mean it won't affect your emissions? Isn't that it's sole purpose?
TGO is offline
