Ellwein Engines :) - Chevy Impala SS Forum
 5Likes
post #1 of 25 (permalink) Old 06-07-2017, 08:40 PM Thread Starter
Ellwein Engines :)
I received my ERE-383 today and I am stoked about getting the engine into my Impala.
The original build made 499hp/515tq. But the motor was damaged during shipping where Karl had to disassemble and reassemble the motor to replace the damaged parts. Karl was fantastic in all of this.... I highly recommend.
On the motor Dyno again --- 515.7hp @6000 rpm 523.9tq @4400 rpm. This combination makes 504.6tq @ 3300 rpm with a nice flat torque curve.
More to follow as I install the engine into my Impala.
Later,
Michael
Lance and nsaness like this.
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 in process with LE TFS heads.
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
post #2 of 25 (permalink) Old 06-07-2017, 11:30 PM
TGO
Wow what got damaged?
TGO is offline
post #3 of 25 (permalink) Old 06-08-2017, 11:03 AM
The Bolt-On Terror's Avatar
Excellent numbers, Michael!
Small cam and great heads make for a big fat powerband
Lance likes this.
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #4 of 25 (permalink) Old 06-08-2017, 02:49 PM Thread Starter
The shipper dropped the engine and it tumbled over. Some of the rocker are bolts were bent where the rocker arms were touching. The harmonic balancer was also damaged. The motor was covered in sand/mud and was inside the engine. Karl disassembled to clean and make sure that nothing else was bent. He wanted to ensure that the valves did not contact the pistons and clean up the sand and dirt inside the motor.
All is good now.
Kudos to Karl
Michael
madamorr is offline
post #5 of 25 (permalink) Old 06-08-2017, 04:59 PM
Send a message via AIM to FaSSt9602
All is good now.
Kudos to Karl
Michael
Wow, that is quite the FUBAR by the freight company...
What are the specs on the heads and cam?
1996 DGGM Impala SS
Project Resurrection 396 in the works!
FaSSt9602 is offline
post #6 of 25 (permalink) Old 06-08-2017, 05:47 PM Thread Starter
Heads are from Lloyd Elliot:
TrickFlow LT1 aluminum heads. new castings. Upgraded 2.08/1.60 valves. 215 cc intake runner flowing 300+ cfm. Spring upgrade for a .700 lift
Camshaft:
Lloyd Elliot custom grind from Comp Cams: 223/231 .581/.584 112LSA
Compression Ratio:
11.1 to 1
Karl and Lloyd specified all the parts based on my intended usage.
Michael
madamorr is offline
post #7 of 25 (permalink) Old 06-08-2017, 08:09 PM
TGO
All is good now.
Kudos to Karl
Michael
whaaaaaaaaat? that's crazy!
TGO is offline
post #8 of 25 (permalink) Old 06-09-2017, 09:45 AM
Camshaft:
Compression Ratio:
11.1 to 1
Michael
Very nice! Very similar to my set-up, only I've got slightly higher CR and a bit bigger bump stick...
1996 DGGM Impala SS
post #9 of 25 (permalink) Old 06-09-2017, 03:49 PM
RatSSled's Avatar
Sounds like an error in your favor, collect 16HP and 9ft#.
A bit bigger bump stick????
Did that happen in shipping too?
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
RatSSled is offline
post #10 of 25 (permalink) Old 06-12-2017, 12:10 PM Thread Starter
More progress.
I removed the motor from the shipping crate and put it on my engine stand.
I installed the Opti, WP, headers, misc brackets, plug wires and various sensors. Getting close to be able to stuff into the Impala.
ID:	160298   Click image for larger version
ID:	160306   Click image for larger version
ID:	160314   Click image for larger version
Lance likes this.
madamorr is offline
