LS Swap Basics - Page 82 - Chevy Impala SS Forum
 4Likes
post #811 of 1257 (permalink) Old 01-07-2013, 02:26 PM
Originally Posted by dirtyharry View Post
Cpt shane is not building trans no more...for fi. Go on ls1tech.com a lot if info on there
yeah I know. got one of the last ones he built. I guess step one at this point is trying to decide which engine/trans options to go with.
jamey is offline
post #812 of 1257 (permalink) Old 01-07-2013, 11:03 PM
jimmyjam's Avatar
Originally Posted by jamey View Post
so after reading for a few hours i'm not sure the direction to go. 94 caprice, decently built 4l60 from shane, wanting to swap in a FI 5.3/6.0 and potentially a 4l80 if needs be, for a goal of 500-600whp with either a roots blower or a rear mount turbo setup. looking for kind of a check list of parts, advise, to make a to do list lol. lots of planning and prep to do and kind of overwhelmed with where to start. thoughts? suggestions?
skip the rear mount turbo. where are you going to put it? if it ends up by the axle, screw it, waste of time, its going to lag like a mug. if you delete ABS there is a ton of room under the hood to do a front mount. otherwise a tvs 1900 will get you in the 500rwhp range or go 2300 and set your sights higher
1996 Impala SS - DCM - LS swap in progress...
2006 Trailblazer SS - 402ci LS2, RWD 4L80 swap
jimmyjam is offline
post #813 of 1257 (permalink) Old 01-22-2013, 11:00 AM
Send a message via AIM to fast lt1
Well i've starting looking for a motor and i've been researching some and i'm wondering if the 6sp Auto transmissions out of the Silverado 1500's will fit in the Impala's without major modification.
fast lt1 is offline
post #814 of 1257 (permalink) Old 01-22-2013, 02:09 PM
SStreet King's Avatar
Threw this little video together the other night.
1996 BBB Impala SS: SOLD
Heads/Cam LS3 500RWHP (Mustang dyno)
Built and Tuned by Tune Time Performance.
2012 CTS V:
10.24@137MPH - http://youtu.be/o9hapMTspEg
SStreet King is offline
post #815 of 1257 (permalink) Old 01-23-2013, 07:31 AM
jimmyjam's Avatar
thought i'd share a pic, haven't seen anyone run gen5 Camaro accessories
the stock alternator pulley is pretty large, replaced it with one off of a truck alt I had laying around. also had to massage the steering gear for clearance. and lastly, move the abs box over about 1" (note the mount on the gear box) to clear the ps pump
I have a question, what do people do about coupling radiator hoses? the only thing I could find locally are nylon couplers at home depot, do you think they will be ok at operating temp?
jimmyjam is offline
post #816 of 1257 (permalink) Old 01-23-2013, 10:04 AM Thread Starter
GA95DCMSS's Avatar
Send a message via Yahoo to GA95DCMSS
Jimmy, to couple the radiator hoses, I used an aluminum adapter from jagsthatrun. Mine has a port for the steam line, and a bleeder valve on it to assist with getting rid of air. I'll look and see what hose I used, as we are using the same water pump and PS pump setup. IIRC I just bought a new Lower hose for the Lt1 Impala SS and used it for the top connection.
You can see the adapter in the photo above the oil filter (in the radiator hose of course).
Quentin-1995 Impala SS-. New PB coming soon
GA95DCMSS is offline
post #817 of 1257 (permalink) Old 01-24-2013, 05:58 PM
NY State Inspection?
Excellent forumÖÖ.
I have learned so much, thank you.
Iíve read through a lot of posts and unless Iíve missed something, will the conversion pass a NY State Inspection?
Mac9955 is offline
post #818 of 1257 (permalink) Old 01-24-2013, 08:29 PM
jimmyjam's Avatar
do you mind feeding my curiosity? it seems like you've connected the steam line to the nipple on the coolant reservoir, using a T, is the other side of the T capped?
jimmyjam is offline
post #819 of 1257 (permalink) Old 01-25-2013, 04:07 PM Thread Starter
GA95DCMSS's Avatar
There is no T in that photo, it was run straight to the coolant reservoir. I switched it to a T in the new setup as there isn't anywhere on my factory radiator to run it.
post #820 of 1257 (permalink) Old 01-25-2013, 07:31 PM
dirtyharry's Avatar
Here my new setup
D.C INC........ Trigger Man
Got work? Got mods? Got LSX?
dirtyharry is offline
