idiot oil pressure gauge resistor picture - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 11-23-2009, 08:24 PM Thread Starter
Many of our cars had oil pressure gauges that don't really read oil pressure, they either read no pressure or good pressure because the gauge is hooked up to a pressure switch that's on when you have only about 5 pounds of pressure. 5 pounds isn't good oil pressure. The switch was meant for an oil pressure idiot light. I was cleaning out my photobucket account and found this, I posted it a while back-
I figured I should post it again since the great crash wiped it out. This is the resistor that must be removed if you want your oil pressure gauge to work with a pressure sender instead of a pressure switch. It took me a while to find this little sucker, it's in the harness that runs right along the inside of the top of the glove box opening. Just snip out the resistor and tape off the wires, don't connect them together! Just snip out the resistor and insulate the bare ends that are left over. Someone had a good writeup about it that had all the part numbers. After removing this resistor, swap out the pressure switch for a sender. From what I remember there's a direct replacement sender that works OK, I think it was used on the 9C1. The hot setup is to use a sender from an S10, the threads are different so you need to use some adapters but it uses more of the gauge scale, this is what I did and it works great.
Maybe the OP will chime in and post the rest of the details.
95 RM wagon
96 Caprice B4U
94 Caprice B4U
2000 Dodge Caravan http://www.youtube.com/watch?v=Rdi8EkTGztY
turbochris is offline
post #2 of 7 (permalink) Old 11-23-2009, 08:44 PM
HuSSker's Avatar
The rest of the story
STILL better than 9C1 oil pressure sender mod!
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
post #3 of 7 (permalink) Old 11-23-2009, 08:48 PM Thread Starter
thanks!, The circle is complete. I posted a link on your writeup
Chris
95 RM wagon
96 Caprice B4U
94 Caprice B4U
post #4 of 7 (permalink) Old 11-23-2009, 08:52 PM
HuSSker's Avatar
Chris
You might be the ONLY person on ISSF to actually remember to take a picture of that resistor!
'94 Impala SS
SSRI
Herter tuned
HuSSker is offline
post #5 of 7 (permalink) Old 11-23-2009, 08:58 PM Thread Starter
You don't want to know how much of my dash got ripped up looking for this thing. It's nice to have a working gauge. I went from the in radiator oil cooler to a 9C1 type separate oil cooler and I got a little more oil pressure out of the deal. When the engine and weather are cold the gauge now reads almost full scale. When it's really hot it reads a litle more than half idling.
Chris
95 RM wagon
96 Caprice B4U
94 Caprice B4U
post #6 of 7 (permalink) Old 11-23-2009, 09:02 PM
jayoldschool's Avatar
First time in 9 years that I have seen a pic of this. Nice job.
jayoldschool is offline
post #7 of 7 (permalink) Old 11-24-2009, 08:38 AM
Lightbulb
Why in the heck would the general install such a piece of caca of a gauge? Perhaps too much warranty work with a gauge that moves like it should,instead of the "I'm on" "I'm off" gauge
'96 Caprice LT1
48K Miles
1 of 2 made w/ option list, K&N Cold air, Custom tune by Bryan
'03 Ram 3500 dually QC Laramie Sport 4x4 w/built 47 series trans w/custom BD VB and TC, Cummins B series ,Volant Cold air kit/Ram air,Smarty S-06 POD,AirDog lift pump,Centramatic Balancers,FS-2500 By-pass filter system.SpynTec Free Spin Hubs
retirednak is offline
