5.3 truck with Impala/Caprice 4L60E - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 03-01-2011, 07:06 AM Thread Starter
alfurious's Avatar
Does any one know if 2001 Tahoe 5.3 engine will work correct with 95 Caprice 4L60E?
I mean what kind of differeces has Caprice 4l60E and 4L60E with separate bellhousing?
I bought my LM7 engine more than a year ago and still unable to find 4L60E with separate bellhousing
1992 Chevrolet Caprice Classic Brougham L05 TBI-POS
alfurious is offline
post #2 of 12 (permalink) Old 03-01-2011, 08:52 AM
GA95DCMSS's Avatar
Send a message via Yahoo to GA95DCMSS
Yes, it will. Read my sticky at the top of this sectiono titled "LS Swap Basics"
Quentin-1995 Impala SS-. New PB coming soon
GA95DCMSS is offline
post #3 of 12 (permalink) Old 03-01-2011, 09:14 AM
ls1caprice's Avatar
First you will need to be sure the 4l603 has the later style plug on it, and then theres an adapter that can be purchased from GM or Hughes Performance.
Staying true to the all mighty BOWTIE. 94'BBB Imp-SS-5.3 bored to 5.7 custom cam, Powerdyne SC, 4L65E, 3.73's; 78' Malibu-396ci LT1/TH400/3.90's and 250hp shot; 80' Caprice Landau Coupe 346ci LS1/4L60E/3.73's; 89' Silverado GM crate 350/330hp Vortec/700R4/4.11's; 96 Express 1500 turtle-top Conv-van stock 5700Vortec/4L60E.
ls1caprice is offline
post #4 of 12 (permalink) Old 03-02-2011, 09:08 AM
Beertestr's Avatar
Huh?
I have an 01 motor in my 94 Silvy with a 94 trans. Plugged right in.
Motor fits well, intake requries body mods to fit. Run a car intake.
Michael -1979 Caprice LS1 - e.t.... recomputing
KDS-Performance.com
Beertestr is offline
post #5 of 12 (permalink) Old 03-02-2011, 09:57 PM Thread Starter
alfurious's Avatar
Originally Posted by Beertestr View Post
Huh?
Have you reflashed the ECM? or you just use Silvy's ECM as is?
post #6 of 12 (permalink) Old 03-03-2011, 07:13 AM
Beertestr's Avatar
Not sure I understand your Q. The connector is the same. If you run a non-PWM trans (pre 95), you need to change the trans cal and shut off ECCC (Electronic Converter Clutch Control) so that the TCC will lock up. The connector physically plugs in, but the 2001 harness will have 2 more wires in the 16 pin connector, there's just nothing to connect to on the internal trans harness.
I used the 2001 Silvy engine harness. When I had the motor in my 93 2WD Sierra, I used an LS trans and could use the ECCC. When I put the motor into my 94 Z71, I kept the stock trans and shut the ECCC function off in the cal. Most tuners can do that for you pretty easy.
KDS-Performance.com
post #7 of 12 (permalink) Old 03-03-2011, 11:43 AM Thread Starter
alfurious's Avatar
Is there any way I could find out if my tranny is PWM or not?
Thanks for the answers guys!!!
post #8 of 12 (permalink) Old 03-03-2011, 02:32 PM
Banned
Pull the transmission oil pump off. there should be the letters PWM in raised print on the pump. If it is Pulse Width Modulated, the PWM sign will be on the pump.
LT Scholz is offline
post #9 of 12 (permalink) Old 03-03-2011, 04:35 PM
Beertestr's Avatar
Don't need to pull the pump, just need to pull the torque converter. the PWM marking is visible on the front face of the pump.
KDS-Performance.com
post #10 of 12 (permalink) Old 03-03-2011, 10:33 PM Thread Starter
alfurious's Avatar
Do you know if it is possible to convert nonPWM to PWM tranny?
how does it work?
