Double roller vs. stock replacement timing chain - Page 2 - Chevy Impala SS Forum
post #11 of 17 (permalink) Old 03-28-2012, 10:12 AM
Send a message via AIM to mess21
Originally Posted by The Bolt-On Terror View Post
Jerry, I'd stick with stock or Cloyes (Cloyes made the factory timing sets for all the LT1/LT4 engines).
Offhand, I can only remember the p/n for the ED single roller set without WP drive provision. It's the one I'm running: Cloyes 3157. I have some other Cloyes part numbers for both stock-type replacement set, and for an oversize crank sprocket that tightens up the stock chain. I'll post them tomorrow.
A benefit of using the Cloyes part numbers instead of the GM part numbers is that you'll get a tighter fitting timing set. Cloyes made the GM parts with additional slack per the General's requirement to facilitate assembly line operations.
There's no reason to run a double roller. The ED single roller is just as strong, per Cloyes, and they sell them both for our application.
If you really want a double roller just to say you run a double roller, that's Cloyes 3145
The 3145 sometimes requires minimal grinding on the front of the block for clearance. The 3157 does not.
I'm in need of a new timing set for my new 383. I had a low mile gmpp timing set but do to a faliure the crank pully is messed up. Since I can't find just a crank pulley I need a new set. I looked up the cloyes 3157 and summit dosen't show it for a LTx motor, they only show this cloyes set CLO-9-3651X3 and is more then twice the price!! whats the difference?? I run a electric WP if that matters and the car is a 96. I'm a little confused.
96 BBB
LISST
RAISS, 503cam, lt4 heads/intake, 1.6rr's, 52mm tb, tri-y's , pypesX, spintechs, Meziere HD, BH OBD1 tune, CPTlevel3.5, 3600 edge, 3.73\'s, vogtlands, bilsteins, PPM front end, earls 5 line kit, 10%underdrive HB, umi U/L RCAs,f-body MAF, racetronix kit, 30lbsvo...
mess21 is offline
post #12 of 17 (permalink) Old 03-28-2012, 10:20 AM
The Bolt-On Terror's Avatar
Which GM timing set do you have? If it's the standard LT1 setup, then the Cloyes p/n for the crank sprocket is S505.
If it's the GM Extreme Duty LT4 set, call Cloyes at 479-963-2105, and I bet they can point you to the right part for that crank sprocket too.
You're right, Summit will not list the 3157 as applicable to the LTx because it has no WP drive provisions. Since you're running an electric WP, you can use the 3157 set.
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #13 of 17 (permalink) Old 03-28-2012, 10:26 AM
Yea I was running the GM extreme Duty LT4 set. Thanks for the info and fast reply!! I'm def gonna give Cloyes a call and see if I can get just the crank sproket for my set. I went with the LT4 set last time case it was highly recommended. If I have to buy another one I don't wanna cheap out but the GM extreme LT4 costs almost 3 times as much as the 3157!!
96 BBB
LISST
mess21 is offline
post #14 of 17 (permalink) Old 03-28-2012, 10:44 AM
FYI - I just bought the Cloyes C-3039 to replace my stocker while I had the Pan and cover off. What I found was just to remove the Cam sprocket and Chain, I still had to pull the crank gear. The pin on the cam comes out so far, there was not enough slack in the chain to have it clear the cam pin. Also had the same issue installing.
I took some pics of the install and will post up a thread on this when I get some time.
post #15 of 17 (permalink) Old 03-28-2012, 11:03 AM
angelo's Avatar
Originally Posted by heatman74 View Post
Do something different and run gear drive, then slap a supercharged emblem on the trunk and call it day...
oh, btw, YES gear drive can be run on a EFI engine with out problems(knock sensor.) I have it on my 89 K5 Blazer. Middle of summer in Arizona, AC on FULL, running the crap 87 octane. 169k mi. Well atleast for me, anyways...
Sorry to Hi-jack Jerry....
So there is a brand & part # for Gear Drive for our LT1's if we wanna ditch the
timing chain and sprockets ???? Never new anyone made those parts....
-ALF out..
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #16 of 17 (permalink) Old 03-28-2012, 11:53 AM
Blue Wail's Avatar
If you rotate the cam sprocket until the dowel pin is on the top, then unbolt the sprocket, the sprocket will come off. OR you can unbolt the sprocket, rotate the crank and the sprocket will slip off. This can all be done ifall the rocker arms are removed or loose.
-Nab
Blue Wail is offline
post #17 of 17 (permalink) Old 03-28-2012, 01:12 PM
-Nab
yeah, I had the dowel at the 3:00 (#1 TDC) position when I started or 9:00 (#6 TDC) for Pan removal. Would have never thought to move it but didn't want to disturb the engine too much. Sure sounds like a simple fix, wish I knew that before. Pain trying to pull the lower sprocket with the chain still attached.
