Headers Question - Page 2 - Chevy Impala SS Forum
post #11 of 17 (permalink) Old 04-04-2012, 09:05 AM
Hilpala SS's Avatar
Send a message via AIM to Hilpala SS
Yep 1slow96 that was I and they were uncoated, but I also didn't care for the design; being the way they curled up and somewhat seemed in the way. It was more a combination of sorts that led me to abandon them. But like you said to each its own and I'm glad there are some people that made them work and used them to their advantage.
Hil Was Here...
Originally Posted by ProTools4 View Post
at some point a large overlap high compression motor with long tubes is going to shake & make so much sound that all metal spherical suspension noise transfer is another musician in the symphony of "Hot Muscle Cars Rule" in B minor
Hilpala SS is offline
post #12 of 17 (permalink) Old 04-04-2012, 04:07 PM
i995impalass's Avatar
I agree with you guys they do take some work and care with the A/C lines, wiper motor harness, and heater core lines but that trouble is worth it to me for the sound I get. I'v been running my hookers since 03 and no issues. I'm all for trying another set of headers, I would just like the same sound I have.
i995impalass is offline
post #13 of 17 (permalink) Old 04-04-2012, 04:25 PM
Headers Question
I had forgotten about the wiper motor,since mine is deleted. As for the heater hoses,some replacement hoses come with a tight 90 degree on one end. With the 90 degree ends to the core, my hoses continue under the airbox,tight to the firewall,coming out near the fuse center,and rejoining the original hose route near coolant reservoir. After installing some heat sleeve,the hoses are away from the headers,except for the final bend into heater core. I've also been wondering about using "header wrap" on the a/c lines. Seems to me it would help a lot.
post #14 of 17 (permalink) Old 04-10-2012, 03:14 AM
Long tubes
Any body know sum long tubes header that will fit in the impala ss 95 Lt1
AdgPuniSSher is offline
post #15 of 17 (permalink) Old 04-10-2012, 03:27 AM
There aren't any. Everyone stopped making headers for B-Bodies, because nobody bothers to read the stickies!! <---- HINT HINT HINT.
heatman74 is offline
post #16 of 17 (permalink) Old 04-10-2012, 09:09 AM
Gregg-O's Avatar
Look for Clear Image
Header & Catback options list.
Gregg-O is offline
post #17 of 17 (permalink) Old 04-11-2012, 03:51 PM
Here are a set of BBK headers. http://www.summitracing.com/parts/BBK-15950/
Taylormade08 is offline
