New Golen 396 Long Block - Chevy Impala SS Forum
post #1 of 24 (permalink) Old 01-16-2013, 08:31 AM Thread Starter
I recently had Chad at Golen start work on my 396 long block for my 96 RMW. My question is in regard to camshaft selection. We've got it narrowed down to either the Comp 466 or Comp 467. Chad says either will work good with the 467 making more power for sure. I'm just curious if anyone has any experience with either camshaft and how they'll preform with our heavy cars. I'd go with the 467 but I was wondering if the 466 might be a better choice because it might have alittle bit more low end grunt. Thanks !
http://www.summitracing.com/parts/cca-07-467-8
http://www.summitracing.com/parts/cca-08-466-8
'Merica
SirBunnyEater is offline
post #2 of 24 (permalink) Old 01-16-2013, 10:11 AM
'Merica
I run the 466 in my Golen 383 short block. yeah the 467 would make more power but emissions, idle quality and low end TQ were my choice.
Car passes Calif. smog test with no voodoo, just drive in and test. The tune has a great deal to do with this also.
If emissions are not your concern and you want a more aggressive idle, more power in upper RPM than the 467
On a note about your stroker build, have Golen use extended main cap studs (Miloden) on the 3 that hold the windage tray. You can use the stock tray but need to use 1/8" spacers to raise the tray away from rotateing assembly if re-using the 3 stock extended studs. The Miloden you just use a nut under the tray and one over it at a height that allows clearance.
There are also aftermarket windage tray you could use but my $.02 is run a windage tray.
The pic is with the stock extended studs with washers. You also need to add the spacer between the tray and oil pump bolt also.
Name:	G383 windage tray.jpg
post #3 of 24 (permalink) Old 01-16-2013, 12:16 PM Thread Starter
Thanks for the advice. Emissions are not an issue but drivability is so I think I'll go with the 466
post #4 of 24 (permalink) Old 01-16-2013, 07:20 PM
what yours, mine or others definition of "driveability" is subjective. I am sure there are people who feel the driveability of the 467 would be fine. The 466 will make it's TQ and HP sooner in the RPM band than the 467 with the 467 making more HP at a higher RPM
My idle with the 466 is by no means "stock" but very tame. Just enough a "car guys" ear would know something is there. I have a stick car so I can have a slightly lower RPM idle than Auto but nothing "lopy" at all.
post #5 of 24 (permalink) Old 01-20-2013, 12:11 AM
KW Baraka's Avatar
......My question is in regard to camshaft selection.........
'Merica
What gears are you running?
KW
KW Baraka is offline
post #6 of 24 (permalink) Old 01-20-2013, 06:00 AM
The Bolt-On Terror's Avatar
KW
And what's the compresion ratio of the motor?
And what torque converter will you run with it?
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #7 of 24 (permalink) Old 01-20-2013, 11:56 PM
KW Baraka's Avatar
Originally Posted by The Bolt-On Terror View Post
And what's the compresion ratio of the motor?......
That's a damn good question.
You'd like to thing that Golen would adjust the CR for the cam (decking the block to the 'optimal' height)......but that'd probably be asking too much.....
KW
post #8 of 24 (permalink) Old 01-21-2013, 10:10 AM
from Golen web site on the LT1 396...
Peak Horsepower: 550bhp @ 6500rpm Peak Torque: 500lb/ft @ 4000rpm Compression Ratio: 11.5:1
Operating Range: 2300 6500rpm
Required Fuel: 91+ Octane Pump Gasoline
Base Price: $7,999
Block Specifications:
Block:
Crank:
-GM LT1 Cast Iron Block
-Eagle 4340 Forged Steel
-Zero Decked
-3.875 stroke
-Bored 4.030
-Internally Balanced Front and Rear
-Honed with Torque Plates and Pressure Washed
-New Durabond Cam Bearings Installed
Rods:
-4-Bolt Main Caps Installed, Line Bore and Hone
-Scat 4340 Forged I-Beam
-ARP Main Studs
-6.000 Length
-ARP Rod Bolts
Pistons:
-Mahle Forged pistons with Anti-Friction Coating
Rings:
-Mahle Plasma Rings
Bearings:
-ACL H-Series Main and Rod Bearings
Camshaft:
-Comp Cams Hydraulic Roller
Lifters:
Timing Set:
-GM LT4 Extreme Duty Roller Timing Set
Covers:
-Canton 6 Quart Road Race
Oil Delivery:
-GM Factory LT1 Timing Cover
-Melling Select Performance
-Melling Pick Up Tube Tig Welded
-Melling HD Drive
Page 2 of 2
Gaskets:
-Fel Pro Head Gaskets .040
-Fel Pro Performance Oil Pan, Timing Cover Gaskets
Cylinder Head Specifications:
Type: Combustion Chamber:
-New AFR 195cc CNC Ported Eliminator -65cc Combustion Chambers
Intake Valves: Spring Package:
-Stainless Steel 2.05 - Double Valve Springs
-Hardened Retainers and Locks
Exhaust Valves:
-Stainless Steel 1.6 Head Bolts:
-ARP Performance
Pushrods:
-Smith Brothers 5/16 .083 Wall Hardened
Rocker Arms:
-Comp Cams Ultra Pro Magnum 1.6 ratio
post #9 of 24 (permalink) Old 01-21-2013, 10:22 AM
Defintely the 467.
It will be more pump-gas friendly and will give up little-to-no bottom end in a 396 with that healthy CR.
The 466 is too small for that CR in a stroker. It's more suited to a 350/355 with stock-to-mild compression.
Edit: Sorry, I thought that build sheet was from the OP.
So..........I guess he needs to verify if that's what HIS engine is being built to.
NA: 10.98 @ 122
post #10 of 24 (permalink) Old 01-21-2013, 11:52 AM
The OP will have to decide what his priority is regarding max HP potential or a build more suited for "street" driving conditions...where 6500 RPM area is not often used.
the 467 will make more HP...but at a higher RPM than the 466 reaches its max HP
smaller cams in "stroker" motors work. Some have even used the Longenfelter 211/219 cam.
All comes down to what the owner feels is best for his use.
