fuel pressure - Chevy Impala SS Forum
post #1 of 16 (permalink) Old 01-20-2013, 11:25 PM Thread Starter
fuel pressure
just wondering when is it needed to have a adjustable fuel pressure regulator?
Ecam racing engines
naSStyboy9c1 is offline
post #2 of 16 (permalink) Old 01-20-2013, 11:46 PM
4x4high's Avatar
When you install a much larger cam, heads, and larger exhaust system that requires more fuel to make more HP along with an ECM tune.
4x4high is offline
post #3 of 16 (permalink) Old 01-20-2013, 11:59 PM
KW Baraka's Avatar
If you're not running nitrous.....don't bother. Stick with a stock, non-adjustable FPR.
KW
KW Baraka is offline
post #4 of 16 (permalink) Old 01-21-2013, 05:57 AM
The Bolt-On Terror's Avatar
None of the above; cam, heads, exhaust, nitrous, call for an AFPR ...... in my opinion.
Far less than 1% of the people running LT1 engines are doing the things that would call for it.
A long time ago, before I knew much about these cars, I ran one. Now I try to do things the right way.
Instead of going into the explanations, I'll first just ask: what are you trying to accomplish?
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #5 of 16 (permalink) Old 01-21-2013, 08:41 AM
RatSSled's Avatar
Perhaps he's installing a carburetor!
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
RatSSled is offline
post #6 of 16 (permalink) Old 01-21-2013, 08:54 AM
ya got me there!
post #7 of 16 (permalink) Old 01-21-2013, 11:45 AM
GuillaumeC's Avatar
KW
Why would one need an adjustable FPR with nitrous?
Guillaume Charest
1995 DGGM Caprice, 355ci twin turbo, TH400, F.A.S.T. EFI, 4200 lbs street car 9.96 @ 141.2 mph **SOLD**
1989 Mazda RX7 Turbo II, 357ci LT1, AI 215cc heads, single plane, GTX4708R turbo, TH400, 8.8" SAS, Holley Dominator EFI
GuillaumeC is offline
post #8 of 16 (permalink) Old 01-21-2013, 02:22 PM
When your fuel injectors are a bit small for the engine and you have fuel pump that is efficient at a higher pressure, an adjustable regulator can be used to prevent injectors from working overtime.
93 Mazda RX-7 - Heads/Cam LS1, T56 - sold
95 Chevy Caprice - Golen LT4 383, LE3 heads/cam - no more
Ram Air 383 is offline
post #9 of 16 (permalink) Old 01-21-2013, 02:47 PM
KW Baraka's Avatar
Having the regulator dialed down for normal street driving......and have the option of dialing it up when you're gonna spray.
Or so I've been told.
KW
post #10 of 16 (permalink) Old 01-21-2013, 03:07 PM
GuillaumeC's Avatar
Not sure I agree with that...
If you need a bump in fuel pressure when spraying then I think you have the wrong fuel jet size.
Just my opinion, I could be wrong.
Guillaume Charest
