alarm install? - Page 4 - Chevy Impala SS Forum
post #31 of 37 (permalink) Old 09-14-2010, 08:25 PM
LS
LS's Avatar
wire diagram
Do you have the wire diagram for a 96 caprice? L99
Thanks
What do you guys think about the vipor 5901 or the prestige 997? I need to upgrade my alarm.
1996 DGGM (underconstruction)
1996 BBB (R.I.P. 2001)
1996 Caprice (R.I.P. 2013)
1970 Cadillac Sedan de Ville (uc)
LS is offline
post #32 of 37 (permalink) Old 02-25-2011, 01:34 PM
SS DD's Avatar
Viper 791xv
I've had this alarm sitting on the shelf for YEARS!
Do you have a diagram for the 96impala? I've already had to bypass my VATS so I'd like to use the remote start and all the other goodies that come with it.
Included options
*User-friendly 2-Way remote with the
Ultimate 2-Way Security and Remote Start
system!
*Responder Technology: Unique LCD
Interface for 2-Way communication of
command confirmations and trigger events!
*Confirms all commands with easy-to
understand icons, plus text!
*Alerts users to security system triggers by
Beeping or Vibrating!
*Responder alerts you when
too far away to hear it.
*Only available 2-Way
Remotes with 66-bit Code-Hopping!
*Vehicle Recovery System
*Turbo timer and optional rear
defroster activation output.
*Parking light flash
*Dedicated 1 button start
*+/- Doorlock Polarity Outputs
*One 4-button LCD Remote
*Optional 1 way companion Remote available
*5 channels
*5 zones
*Flashing Blue LED light
*Valet switch
*Domelight Supervision output ready.
*Failsafe Starter kill Built in, along with
Remote Start Anti-grind (active/passive).
*6 Tone Revenger Siren
*Remote Panic/Car Finder
*Super High Frequency Receiver (SHF)
*XCRS-4 relay H/D capacity satellite relay.
*Automatic configuration of remote buttons.
*All models are Clone-Safe Code Hopping
*Diesel mode with dedicated glow plug input.
*Complete engine monitoring: Voltage or Tach
*Programmable run times: 12, 24 or 60 Min.
(0-60 minutes with the Bitwriter tool).
*Dedicated factory security control wires.
*Viper GPS Tracking System: ESP serial port
Viper 791XV now includes the XHF
Super 2-Way Dipole Antenna with
about a 1/4 mile range
ITSSA96
  • Stock 350
  • K&N intake
  • High flow 255LPH fuel pump
  • 24lb Ford SVO injectors (stock, but so nice!)
  • 50 series Flowmasters
  • 400lb Eaton posi
  • 3:73 gears
  • Tri-y's w/Random Tech cats
  • CPT Level 3 tranny (awesome work Shane)
  • OBD1 PCM (great programing Bryan)
  • Precision 22k TC
  • AMSoil 5W30
http://www.cardomain.com/ride/487392/
SS DD is offline
post #33 of 37 (permalink) Old 02-25-2011, 07:16 PM
94MI9C1's Avatar
Go here, this will get you close, this is a diagram that I drew up for people to use, it is a Viper 5901, but generally the pinouts are the same, it may help. download rev A. main difference is you have a separate relay module and the new models have the remote start relays built in to the main unit.
http://www.impalassforum.com/vBullet...09#post2449009
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #34 of 37 (permalink) Old 07-04-2011, 01:15 AM
Thanks for the guide, now I think I'm ready to install my viper 5901.
1996 Impala SS
bigl83 is offline
post #35 of 37 (permalink) Old 07-11-2011, 01:23 PM
rileycoastie's Avatar
hey 94MI9C1 i just purchased a alarm/remote start for my 95 impala. will that diagram for the 94 caprice be the same???
ps i am alot closer than NC i am in tawas city michigan. maybe we can meet up hahaha
rileycoastie is offline
post #36 of 37 (permalink) Old 07-15-2011, 06:53 AM
It should work for your 95 caprice, It worked for my 96 Impala, his diagram is very detailed.
1996 Impala SS
bigl83 is offline
post #37 of 37 (permalink) Old 07-15-2011, 07:35 AM
94MI9C1's Avatar
As stated you should be good to go, there were only slight variances in between the years, but nothing that would affect an alarm install. Sorry for the delay in replying to this, I just saw it.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
