Caprice/impala Alarm Wire Diagram - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 05-18-2010, 06:06 PM Thread Starter
defdaboss's Avatar
IMPALA 94-96
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 BROWN Ignition Switch Harness, (check engine light)
Accessory Orange Ignition Switch Harness
Tach Red/Black Or Pink/Black (-) at Multi Coil Pack
Neutral Safety Wire Orange/Black Gear Select Switch
Brake Switch White Brake Switch
Trunk Release Black/White Switch
Trunk Pin Dark Green (-) Driver's Kick Panel (Rear Body Harness) (96)
Parking Lights Brown Light Switch
Head Lamp Yellow Light Switch
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Behind Driver's Kick Panel
Door Unlock White Positive Trigger
Horn Wire Black (-) Steering Column
CAPRICE
Tach White Or Purple/White (-) At Coil V8 or Multi Coil V6
Trunk Release Black Switch
Door Trigger Blue/White (-) Driver's Pin Switch
(95 caprice classic tow package! 3.73, 1.6RR, beehive springs, HOTCAM, airbox delete, K&N air filter, removed mechanical fan and install electrical fan, tuned
defdaboss is offline
post #2 of 8 (permalink) Old 09-27-2010, 02:02 AM
bad4health's Avatar
good info Cough(the12volt.com) but you should put the VATS wires in there too
95 WX3 BBB, 6.2 Supercharged/Nitrous LSx Swap, 4 SA-12s, Cadence C6, Beyma 6.5s, 300.2, 1/0 Wire, Double Din w/Navi DAILY DRIVER
mods please change bad4healths name to the GREATGORDofISSF. may the pulp be with you :P
bad4health is offline
post #3 of 8 (permalink) Old 09-07-2011, 12:34 AM Thread Starter
defdaboss's Avatar
your dead on! LOL i could update this and hopefully this become sticky. do you know the vats wire color?
post #4 of 8 (permalink) Old 09-07-2011, 12:42 AM
94MI9C1's Avatar
Well here then, little easier to look at a drawing than typed information I drew this up sometime ago for a member that was doing a Viper 5901 or something similar, should be close across the board.
Let me know if this works for you
http://www.impalassforum.com/vBullet...09#post2449009
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #5 of 8 (permalink) Old 01-04-2014, 01:26 PM
coltonx3's Avatar
is its me or are thoes wire colors a lil off from mine beeing a 95 9c1
95 9c1 dggm
straight black pvc kn filter
spintech pro street mufflers
most of trim and grill painted black
150k running strong and going
coltonx3 is offline
post #6 of 8 (permalink) Old 09-22-2015, 07:43 PM
This one covers most vipers remote start alarms made
1999 Camaro 38k
2012 yamaha vxs
lt1ssb is offline
post #7 of 8 (permalink) Old 09-22-2015, 10:21 PM
Erik's Avatar
But doesn't seem to exist any more. If you click through, it says the link isn't valid.
Nodding Tiger Mod
http://www.impalassforum.com/vBulletin/image.php?type=sigpic&userid=15034&dateline=1214775786
Erik is offline
post #8 of 8 (permalink) Old 10-16-2015, 11:29 PM
This diagram is the **** much credit to him for the time
I will add to those wanting the newest LED LCD models like 5906 the
Door lock unlock output on the alarm has kept up with the times and is a positive output only if you want to use this alarm u must use 2 relays one for lock one for unlock if you need the wiring I can send it to you or use a 451m door lock module one will control all 4 doors again if you want I can send it I will post a copy of that here soon as well as the wiring codes for the new vipers
1999 Camaro 38k
2012 yamaha vxs
lt1ssb is offline
