Anyone baffle the 6x9s on the rear of a wagon? - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 08-12-2010, 06:05 AM Thread Starter
bondovw's Avatar
Yea , I know its car audio , This is a wagon only problem ! Anyone do anything to improve the rear 6x9s on a wagon? i was thinking about either fiberglassing the open area so they are sealed or buying the foam 6x9 baffles on e bay. Or should I give up and go work on something else?
I tint tail lights and fix bad bondo!
bondovw is offline
post #2 of 15 (permalink) Old 08-12-2010, 08:02 AM
GoldSSWagon's Avatar
I actually sealed the speaker to the bottom side of the cargo panel with some 2" foam. That way I used the whole cavity of that area as a chamber. Works extremely well. You will like the difference.
GoldSSWagon is offline
post #3 of 15 (permalink) Old 08-12-2010, 08:05 AM
Pat
Pat's Avatar
Send a message via MSN to Pat
GM use to put the foam baffles on their high end cars with the upgrade factory sound system
if you happen to be in a junk yard take a look in the trunks of full sized boxy B and C body GM and you may find GM grey foam 6 X 9 baffles, I gotten them in most of my cars now
Pat is offline
post #4 of 15 (permalink) Old 08-12-2010, 08:40 AM
rematar's Avatar
I tried a little plastic basket built for 6x9s. It had very little volume and my ears claimed it made the sound more tinny.
Goldsswagon, are you talking about a piece of foam like you would take camping? How did you attach it and how big of a space did you create?
05 magnum rt with srt8 300 front
95 dcm wb4 rmw funeral car from fred - sold
93 white woody rmw - sold
rematar is offline
post #5 of 15 (permalink) Old 08-12-2010, 09:11 AM
Sophomore Member
My two cents.
sherlock9c1 is offline
post #6 of 15 (permalink) Old 08-12-2010, 09:39 AM
What I did was to cut a piece of 2" thick foam roughly 8x11 then cut a 6x9 hole in the center of it and sat it over the metal bracket that the speaker is bolted to then pushed the panel back in place. Space wise it created all the area between the wheel wells and the tail lights since the speaker is now sealed against the panel. Think I have a picture at home, can post it this evening if you like.
post #7 of 15 (permalink) Old 08-12-2010, 10:25 AM
Send a message via AIM to Turbo231
I ended up building my own out of foam...not fantastic, but certainly did the job nicely so that it's not awful. Helps the tinny sound quite a bit.
http://www.butchthecat.com/94caprice/speakers.htm
1986 Regal T-Type WH1 - 1999 S-10 4x4 - 1988 Fiero GT - 1994 Caprice Wagon
Turbo231 is offline
post #8 of 15 (permalink) Old 08-12-2010, 10:49 AM
Stingroo's Avatar
Send a message via AIM to Stingroo Send a message via MSN to Stingroo
Yeah, I used the baffles from my Fleetwood.
Stingroo is offline
post #9 of 15 (permalink) Old 08-12-2010, 10:54 AM
Sophomore Member
Those have big slices in the back of them. They aren't sealed by any means. Not sure what GM had them there for (whether aesthetics or protection from luggage or whatever), but clearly it was for something.
post #10 of 15 (permalink) Old 08-12-2010, 12:00 PM
rematar's Avatar
If it is different from turbo231 I would be interested. There's a couple of good links here already.
rematar is offline
