Whats the best way to drain fuel tank? - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 03-07-2011, 04:51 PM Thread Starter
Deadman's Avatar
I bought a 95 Caprice wagon thats been sitting for about 5-8 years, and the fuel tank is mostly full. Whats the easiest way to drain the Gas out without dropping the tank?
I'm tempted to go buy some small hose and use shop vac to get Siphon going, but is there a better/easier way? Years ago, I've bought some of those cheap siphon kits from hardware stores, and most of them are junk and never worked from day one.
Is there a way to drain it by using the fuel pump? I already pulled the fuel filter and ran the fuel pump as I cycled the Ignition, but that was a slow boat to China. Is there a way to run the pump steady maybe?
Thanks
95 Caprice Wagon
Deadman is offline
post #2 of 11 (permalink) Old 03-07-2011, 05:03 PM
Sophomore Member
I just have to say that this is a sure-fire way to cause an explosion. You would be pumping gasoline vapors through a sparking electric motor and then blowing them all around your garage. You really would be a deadman.
Look next to your AC accumulator - there's a little connector. Disconnect the fuel line like you said, aim it into a gas can, then put 12V on that connnector. Done.
sherlock9c1 is offline
post #3 of 11 (permalink) Old 03-07-2011, 05:46 PM
sprocket's Avatar
Disconnect at the fuel filter and get a GOOD connection (no sparks) to run your voltage to the pump and let the pump do the work.
The LT1 tanks have baffles, you'll only get about half out with a siphon anyway. Trust me I know from experience and a few mouth fulls of 87 octane
sprocket is offline
post #4 of 11 (permalink) Old 03-07-2011, 05:54 PM Thread Starter
Deadman's Avatar
Dang it, that sure would have made for a good story tho!
Thanks, I'll try that tomorrow!
95 Caprice Wagon
Deadman is offline
post #5 of 11 (permalink) Old 03-08-2011, 06:59 AM
lakeffect's Avatar
Someone else would have been writing it though. You'd be filed under "Crispy Critters" over at the local Burn Treatment Center.
Do yourself a favor, Assuming you are dropping the tank as part of this project,go get a drain plug from NAPA, Advance Auto etc. They run about five bucks. Put in in. IF you ever drop the tank a second time, you'll be really happy you spend the five bucks. Mine's been out four or five times now. Easiest way to drain the tank when the System is inoperative.
1993 Caprice wagon "SHAMMOO" Kicker demo car. 406ci, TPI'd SBC, 58mm TB, SLP siamesed runners, Comp Cam 230/236, AFR 195 heads, headers. Accel 300+system, remote fan cooled ignition module. Highly modded "4L65" Trans-Go kit, beast sunshell, 5 gear planetaries, B&M megashifter. Shaved roof and tailgate, debadged, billet grill, Front spoiler and rear pan. Custom four bucket interior, Nordskog digital dash. (Reworking current center console) 2" dropped spindles, Bell shocks, BFG's Weld Tomahawks
lakeffect is offline
post #6 of 11 (permalink) Old 03-08-2011, 05:16 PM
Man From Knobstock's Avatar
Best Way to Empty a Gas Tank? Are You Kidding...?
OK, I'll say it, because this is as much of a set up line as I've seen on these boards: The easiest way to drain the gas is to stomp your foot to the floor!
Knobby,
Port Orchard, Washington
1995 Buick Longroof GS Clone Project Car
http://longroofgransport.wordpress.com/
B-Body and Wagon Cruise on the Western Shore of Puget Sound this coming May! Stay tuned.
Man From Knobstock is offline
post #7 of 11 (permalink) Old 03-08-2011, 05:31 PM Thread Starter
Deadman's Avatar
Fuel pump worked great, thanks for info! Stinks bad, it could be 8 yrs old!
95 Caprice Wagon
Deadman is offline
post #8 of 11 (permalink) Old 03-21-2012, 10:31 PM
Phantom59's Avatar
I just went through this had a full tank of gas and a dead fuel pump. You can get about 5 gallons from the fill tube before the baffle stops you. After that if you jack the car up and disconnect the vent line beside the fill neck you can snake a line through there to the center of the tank. I was able to remove about 18 gallons this way and the tank came down very easy.
Phantom59 is offline
post #9 of 11 (permalink) Old 03-22-2012, 05:04 PM
HA. I was going to go with 'Insert Key, first but great minds think a like!
"You guys wanna make jokes, or watch me haul ass?" - rut
VacFink is offline
post #10 of 11 (permalink) Old 03-22-2012, 06:19 PM
nomrlz's Avatar
just drill a hole in the bottom. hands down the easiest
1995 bolt-on RMW (thanks fred)
14.174/94.07 motor stock TB
13.946/96.44 motor 52mm TB
12.365/107.74 150 shot
9.377/152.69 '00 Hayabusa with 270lb rider
8.72/162 99 Hayabusa same fat rider
nomrlz is offline
