Exhaust help - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 08-04-2016, 10:29 AM Thread Starter
jcarl126's Avatar
Exhaust help
Hey guys,
My car came with Borla Catback () which looks very nice buttttt flows and sounds like butt.
So I've now installed CIA long tubes, no cats, to the Borla and my god it's like driving stock exhaust again!!
Anyway, general consensus.... Found a dynomax ultra flow true dual kit (p/n 17375) for $570, or run the jegs dual kit with other mufflers than it comes with (suggestions?)... Or Frankenstein it with a pypes X-pipe, some sort of mufflers, and then dynomax over axle and some nice extension pipes to the rear bumper?
Don't want any drone, but I do like loud and deep! Better to run an X-pipe, or the true duals for performance?
Any votes?
'95 DCM - LT1PCMtuning Tune, TR55ix's, CIA Headers and Catless export pipes, Borla Catback, Moog Steering Rebuild, Vigilante 3.4k, ATi FlexPlate, Tru-Trac, 3.73's, B-Body Perf. Sway Bars, Monroe SS's, F-Body Front Brace, PMT Extended UCA/LCA Combo, '08 P71 CV Alum. DS, Accell Cermic Wires, MSD Coil, CAI, EGR/AIR delete, Home Plate delete, LED 9004s, Clear corners, Gunmetal SS Wheels, Smooth Bumpers, 20% Windows, Armrest Savers, JBL all around
'10 TDi - DD
jcarl126 is offline
post #2 of 9 (permalink) Old 08-04-2016, 10:34 AM
My $.02 is Frankenstein
Pypes X
muffler of choice (SpinTech Pro Street=loud, Sportsman=mild)
DynoMax over axle (2.5")
DynoMax resonators (resonators reduce drone)
post #3 of 9 (permalink) Old 08-04-2016, 12:16 PM
If you haven't already, check the Stickies for good info on the available Cat Back setups that are/were out there. I want in a system is 2.5" pipes, X-Pipe or H-Pipe, OTA tails, Resonator Delete, maybe some Chrome tips/pipes at exit and great sound. Stainless would be nice, but the Aluminized kit on the car now has held up well for lots of years so can't justify that expense. It was even on the car when I had the 4.3 engine which was easily 10+ years ago.
Recently picked up some Tri-Y's and will be replacing the current Flowmaster American Thunder kit that is on there now. I've been happy with it but like the Borla, it's a puny 2.25" design. While I can't speak from personal experience on other systems/mufflers, I can offer up some info on what others have said and the direction I'm now looking to go with the exhaust.
At one point was also strongly considering (Franken-exhaust) the Pypes kit along with a good set of mufflers. I believe the X Pipe section is Stainless but the OTA pipes are aluminized. One thing I don't like is that others have said the X portion hangs pretty low under the car. With a lowered car this could be a problem.
I have had my eye on something from CIA Exhaust for quite a while but the cost seemed high.
High Performance Exhaust Systems - Impala SS Cat-back Exhaust Systems
Their systems come with the Spin Tech Mufflers and you have a few options as well for both Mufflers and Tailpipes....even a 3" full version if you need it. All reviews I've seen on the Spintechs have been great. I have pretty much decided this is who my catback will come from when I'm ready to place the order and from what I've read, his kits fit really well. So if this is a little xtra money, it's almost worth it to me for that. Just my thoughts.....
EDIT - Just noticed you got the long-Tubes so his Cat-Back setup may not work. Maybe he offers something for his headers?
post #4 of 9 (permalink) Old 08-05-2016, 09:01 AM Thread Starter
jcarl126's Avatar
Unfortunately the header ordeal with CIA left quite an unsavory opinion of the business in my mind, and I cannot say I will be ordering anything from Dan or CIA again - which leads to the Franken-exhaust build.
How do these p/n's look to everyone?
Pypes XGi10
Spintech 3334 X 2
Walker/dynomax 21132 and 21133
Walker/dynomax 54016 and 54017
? I will be welding hangers onto the mufflers but everything else should bolt right up with 2.5" band clamps, correct?
'10 TDi - DD
jcarl126 is offline
post #5 of 9 (permalink) Old 08-05-2016, 10:31 AM
Other than the CIA headers that is the same exhaust I have. IDK what Export pipe or CATS OP has but if that winds up where stock CAT pipe placement is than all should "bolt" up. Otherwise there will need to be some custom cutting/welding to mate the X pipe in
FWIW I had my whole system welded vs clamps at a muffler shop. The Pypes X pipe does flange bolt to the CAT pipes
I have also changed to 2 1/2" MagnaFlo CATS and pipe from my headers so I have a full 2 1/2" system
The Sportsman mufflers are not loud but do give a nice exhaust note, IMHO.
I like the turn down tips on the Dynomax resonators. Stainless and tuck up nice under the car
ID:	144865   Click image for larger version
ID:	144873   Click image for larger version
Name:	clutch inst 9 tranny stab.jpg
post #6 of 9 (permalink) Old 08-05-2016, 10:53 AM
Care to share?
atlantadan is offline
post #7 of 9 (permalink) Old 08-05-2016, 11:07 AM
Under the guise of damage control and recovery, and if I read your current config right, why not just swap in 2 1/2" collectors and front pipes and call it a day. I believe lots of the scavenging occurs up front anyway, and CW seems to point at 2 1/4" is more efficient than anything larger out the back - unless really super dooper horses.
You might get a pair of 2 1/2" in - 2 1/4" out if the 'notoriously too quiet Borla muffs' keep antagonizing you.
Sure it's a work-around, but also not $600 either.
Also,
Any votes?
Never never don't run (triple negative) true dual - 'cept of course a quarter miler. Proven better offline torque with either an H- or (much more expensive but way prettier) X-.
96 Black is online now
post #8 of 9 (permalink) Old 08-05-2016, 11:17 AM
Originally Posted by atlantadan View Post
Care to share?
Well, if this is it, then my interest is in what clearancing a header entails. Port-matching? Grinding the flange welds flat?
Hypothetical HCI while waiting
post #9 of 9 (permalink) Old 08-05-2016, 12:29 PM
I'm running CIA Tri-Y's. There is nothing required to use them. They literally drop right in - zero fitment issues at all. They clear everything.
If the OP is referring to this thread, the problem has nothing to do with CIA.
