Earls header gaskets? - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 08-05-2016, 08:45 PM Thread Starter
Thump's Avatar
Send a message via AIM to Thump
Currently running these but want to take my Tri-y's off to have them recoated.
Can you guys verify that
https://www.summitracing.com/parts/ear-29da3berl
are the correct models for LT1?
Thanks guys.
Thump is offline
post #2 of 10 (permalink) Old 08-05-2016, 09:07 PM
ocala's Avatar
That's correct. I'm using the same set.
If you're sure this is what you have now, you can just buy the inserts.
ocala is offline
post #3 of 10 (permalink) Old 08-05-2016, 09:12 PM
ocala's Avatar
https://m.summitracing.com/parts/ear-29d03b3erl
ocala is offline
post #4 of 10 (permalink) Old 08-06-2016, 11:19 AM Thread Starter
Thump's Avatar
I was hopin to get just the inserts, but Im unsure what model I put on back in 05!
Thump is offline
post #5 of 10 (permalink) Old 08-14-2016, 05:53 PM
MafioSSo's Avatar
The inserts part number is 29D03B3ERL.
1995 SixOnTheFloor Impala SS
1995 Caprice Wagon
1994 Caprice Wagon (SOLD)
1996 Wrecked Impala SS (Parted Out & Junked)
1996 Impala SS Clone (SOLD)
MafioSSo is offline
post #6 of 10 (permalink) Old 08-20-2016, 01:35 AM
KoolAidMan's Avatar
And btw, summit does have the whole gasket, but not the insert replacements for LT1. Jegs does have the inserts though.. Incase your wondering why you can't find em on summit
95' 9c1 Caprice - DD - 250k Stock trans, and was still burning rubber in 1st and 2nd
94' 9c1 Caprice - RIP 2014 - 90,000 original miles TOTALED ..and thanks to this beast, walked out with a scratch
CIA Gen II Tri-Ys and Hi flow cats, CAI, SLP Air Foil, Flowmaster mufflers(for now), TransGo HD2, Detriot TrueTrac w/ 3.08, Bilsteins all corners, H&R Lowering Springs, Moog Steering, Stealth Brake And Bolt II Mod, TB bypass, 160 TS, 6K 35W HID and more to come..
KoolAidMan is offline
post #7 of 10 (permalink) Old 08-20-2016, 05:43 PM
juniorwatson's Avatar
As an FYI, I put in an order thru an Amazon seller MONTHS ago, and I still have yet to have that order fulfilled.
I'll most likely go thru Summit or Jegs, just to have them in my toolbox when I need them.
Clear Image Tri-Ys & Hi-Flow cats to CIA 2.5" X-Pipe & Spintech Mufflers, Mike Harris 4L60E, Vigilante 3,400 RPM Converter, MOOG FT end, Del-A-Lum bushings in new MOOG CTRL Arms, Eibach FT Springs, New Stock rears. Hotchkis Sway Bars & End Links, RAISS, Dynoshaft, CIA Driveshaft Loop, BMR Trailing Arms, Braided Brake Hoses, Taylor Spiro-Pro Wires, AutoMeter 2-5/8" Water Temp & Oil PSI Gauges, Impala Console. ATE Blue Brake Fluid. Skip White distributor. Newly Installed 20's on 1/1/2017
juniorwatson is offline
post #8 of 10 (permalink) Old 08-21-2016, 04:09 PM
KoolAidMan's Avatar
I Have a pair in my shack waiting for the day I need to change em out for whatever reason b/c you never know.. Already had to change em out once for a broken exhaust manifold bolt.. What a fun 3 hrs we spent before finally welding up a nut to get it out
post #9 of 10 (permalink) Old 08-21-2016, 04:12 PM
KoolAidMan's Avatar
And I guess summit does have em now, but they sure didn't when I needed them.. I'd get a refund and go with summit b/c they definitely ship the fastest even with free shipping or standard shipping
post #10 of 10 (permalink) Old 09-03-2016, 11:49 PM
TGO
For me, for the $40...I'd just buy a whole new set anyway. And I have in the past.
Peace of mind is worth more than a few dollars for me.
Why are you having your headers recoated?
TGO is offline
