Performance Cat - Chevy Impala SS Forum
 1Likes
  • 1 Post By BALLSS
post #1 of 4 (permalink) Old 10-21-2016, 12:39 PM Thread Starter
6 speed V's Avatar
Performance Cat
Looking for a good performance cat
Any suggestions
Mike
6 speed V is offline
post #2 of 4 (permalink) Old 10-21-2016, 03:33 PM
I don't think the stock CATS cause much of a performance loss if they are still good. Clogged yes any CAT will drop performance.
I replaced mine with the MagnaFlow FWIW. Bought the 2 1/2" in/out size. More because these were CARB/OBD2 approved. If that is not a issue for you something like a Catco would be much cheaper
KW Baraka likes this.
post #3 of 4 (permalink) Old 10-21-2016, 10:16 PM
KW Baraka's Avatar
Originally Posted by BALLSS View Post
.......I replaced mine with the MagnaFlow FWIW. Bought the 2 1/2" in/out size. More because these were CARB/OBD2 approved. If that is not a issue for you something like a Catco would be much cheaper
If you want DIRECT replacement cats for your B-body, the Magnaflows and the Catcos will fill the bill.
They may not be CARB compliant, but they are visually indistinguishable from the OEM cats. I used them when I had SLP shorty headers.....and with a 224/230 cam in a 383ci LT1, I passed Georgia emissions with no problem.
Now.....if you REALLY want hi-flo, performance cats, then you can go that route....but your muffler shop will be doing a bit of fabbing and welding.....and you will pick up close to nothing versus going with the Magnaflows or Catcos.
KW
KW Baraka is offline
post #4 of 4 (permalink) Old 12-28-2016, 05:34 PM
Vendor
We use a very free flowing converter core. They are the spiral wound metal matrix. We can sell you cores with ends only as we no longer stock the factory manifold flange. Or if you choose to go with our headers, we can build the hi-flow cats to work with them.
Clear Image Automotive (425)251-0329
Headers, exhaust & intake systems
dan.ferraro@clearimageautomotive.com
http://www.clearimageautomotive.com/
Clear Image Auto (Dan) is offline
