CIA Headers rusting? - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 10-24-2016, 11:57 AM Thread Starter
TGO
Is this normal? I bought with the ceramic coating and have had them on my car for a little over a year and they are rusting.
TGO is offline
post #2 of 12 (permalink) Old 10-24-2016, 02:06 PM
I've read elsewhere where the "chrome" Chromex coating fails in relatively short order - especially if exposed to salt or damage. The black Chromex tends to hold up a little better. I have a coated CIA set on my car and they're pretty ratty. I'll be buying gen2 stainless ones here pretty quick and then sending my gen1's off to be re-coated.
atlantadan is offline
post #3 of 12 (permalink) Old 10-24-2016, 05:54 PM
While CIA build a very good header, the coating service they use sucks big time. I know from experience. That is why I always suggest that people buy the headers raw, and get them coated locally
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is offline
post #4 of 12 (permalink) Old 10-24-2016, 06:02 PM
ocala's Avatar
You might check this out if you decide to send them off for coating again.
http://swaintech.com/race-coatings/r...aust-coatings/
Here's mine, they do have a scratch but that was from a hard hit during install. It's a tough coating...
ocala is online now
post #5 of 12 (permalink) Old 10-25-2016, 12:23 AM Thread Starter
TGO
Evidently yeah...lol
I have Kooks on my Corvette about 4 years now and they are fine. I also had a set of Kooks that I bought used for a couple of years on my GTO and to my knowledge they are still on the car and still not rusty.
TGO is offline
post #6 of 12 (permalink) Old 10-25-2016, 11:46 AM
jasonlachapelle's Avatar
normal ? no. Common ? yes.
I lost a set of tri-ys to rust perforation. The lifetime warranty should read: warrantied for one re-coat per lifetime.
edit: I drove the car in the winter in Quebec. Visible rust requiring re-coat occurred after 1 winter. Perforation occurred after 2 years.
Jason
1996 Roadmaster Wagon
1995 Caprice Wagon
jasonlachapelle is offline
post #7 of 12 (permalink) Old 10-25-2016, 12:23 PM
Coupled with the place listed above, that's some great advice.
post #8 of 12 (permalink) Old 10-25-2016, 02:45 PM
I have used jet Hot coating on 3 headers/vehicles and all still look good.
headers on the SS were coated 17 years ago and still look good. Granted I don't see road salt/sand here in Calif but do drive the car in the rain...YMMV
post #9 of 12 (permalink) Old 10-26-2016, 12:05 AM Thread Starter
TGO
Yeah the AS&M ones that were on the car were there for at least a decade - and were wrapped - and were totally fine.
What a bitch it's gonna be to pull them off and send them out and wait for them to be recoated.
Even with a warranty on the coating from Performance Coatings I would never use them again. So I'll have to send them somewhere else. Or just wait for them to rot and buy new ones.
TGO is offline
post #10 of 12 (permalink) Old 10-28-2016, 01:14 PM
strokedimpala's Avatar
I have Dans headers in stainless but I had them coated by Jet-Hot before they went on the car.
Paul.
1996 ss 396 lt-4 competition longblock golen engines.custom hood,bumpers,spoiler,20\"billet specialties wheels.3.73.speedtech performance upper and rustic lower control arms.power performance motorsports frontend.body bushings,frame and floorpan painted.tce 14\" 6-piston front kit wit 4-piston 13\"kit in rear.
stainless quad-1 headers w/3" stainless exhaust.
fully painted undercarriage,w stainless bolts everywhere.
strokedimpala is offline
