Replacing Header Bolts - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 06-05-2017, 06:32 AM Thread Starter
AaronR805's Avatar
So i just ordered a pair of new gaskets for my hooker super comp headers, And im thinking i might as well change out the bolts while im at it... Any bolts you guys recommend? A link would be greatly appreciated! Thanks
AaronR805 is offline
post #2 of 4 (permalink) Old 06-05-2017, 08:34 AM
RefineryRob's Avatar
I would use grade 8 bolts with high temp anti-seize. As for the type of head to use it all depends on the clearance between the header tube. My SLP headers it was easiest to use an allen head bolt. Also on the passenger side you'll need to keep the bolt that attaches the support for the alternator. its a normal bolt to the header flange...but it also has a threaded stub out the top to also attach the support for the alternator. I couldn't find a replacement so I just used a threaded stud with a couple nuts.
I believe 3/8" 16 thread. But you should verify. Also about 1-1/8 or 1-1/4 in length. Compare to your originals (they had spacers too). Don't get too long
I would also shoot for 6 sided bolts versus 12. If you can fit a wrench on it.
Rob.
ISSCA Member #2482
1996 Impala BBB: SLP Headers. K&N FIPK, Eibach Pro Kit, ZQ8s. Bilsteins. Gary's Opti, Battery, and Headlight Harness'. Vette Starter. Taylor ThunderVolts. NGKs. Stealth & Metering Bolt. Goodridge Brake lines. TB Bypass. Magnaflow CATs. Air delete. Alex Tune. DynoMax 959's. CrownVic MMC drive shaft. BMR Ext'd RCA's. 373's/Superbrute
GOALS: Road Race Trans/TC, LE1 or AI Heads and CAM.
RefineryRob is offline
post #3 of 4 (permalink) Old 06-05-2017, 09:09 AM
juniorwatson's Avatar
These were recommended to me, and I really like them, ARP Stainless Steel Header Bolts, they've got a 5/16 head so it's easy to get a box end wrench on most of them.
I bought a MAC tools extra-long combination, ratcheting box end wrench, open end, for something like $12 bucks.
It was well worth the investment.
Also as a note I bought some 3/8-16 X 1 studs, and used them on the far ends of the head exhaust bolt holes. It made the installation a BREEZE. First hung the header on, and then slid the header on the studs, and started installing the ARP bolts.
This makes it a one man job.
Clear Image Tri-Ys & Hi-Flow cats to CIA 2.5" X-Pipe & Spintech Mufflers, Mike Harris 4L60E, Vigilante 3,400 RPM Converter, MOOG FT end, Del-A-Lum bushings in new MOOG CTRL Arms, Eibach FT Springs, New Stock rears. Hotchkis Sway Bars & End Links, RAISS, Dynoshaft, CIA Driveshaft Loop, BMR Trailing Arms, Braided Brake Hoses, Taylor Spiro-Pro Wires, AutoMeter 2-5/8" Water Temp & Oil PSI Gauges, Impala Console. ATE Blue Brake Fluid. Skip White distributor. Newly Installed 20's on 1/1/2017
juniorwatson is online now
post #4 of 4 (permalink) Old 06-05-2017, 10:46 AM
ARP or Stage 8 header bolts
I have had the Stage 8 locking ones for 18 years. You need longer bolt for the rear alt bracket. I bought a SS alan head one at the hardware store
