How to Delete your AIR Pump - Page 2 - Chevy Impala SS Forum
post #11 of 272 (permalink) Old 09-18-2009, 06:22 PM
bammax's Avatar
You have to ask for it. Most places have it behind the counter. I ended up buying them 1 at a time since nobody stocked 2 when I was looking for them. And from Autozone they came in a plastic baggy like oem bolts instead of the bubble-packing like in the pic.
bammax is offline
post #12 of 272 (permalink) Old 09-18-2009, 06:24 PM
214Texas's Avatar
At autozone here they said it is not available and they could not order it. O reilly auto didnt show to have it either in stock or at warehouse
INC 4 Life!
RIP Preston Medley & David Fornwalt Ridin 4 You Til We Join You
95 DCM SS # 15,877
All INC related questions go here: http://groups.yahoo.com/group/INC96/
214Texas is offline
post #13 of 272 (permalink) Old 09-18-2009, 06:26 PM
bammax's Avatar
I asked for the plug for a mid 2000's Ram diesel. It ended up being a different part number but it's the right size according to my research
bammax is offline
post #14 of 272 (permalink) Old 09-18-2009, 07:45 PM
214Texas's Avatar
Aight I went back to an autozone here near my job. They found the ones from the back in the bags but the m22-1.50 they wanted $27.99 each for. So i left there and went to o reilly's next door and they ordered them from oklahoma for $3.49 each. Man all this for two #@$^%^@# plugs
INC 4 Life!
95 DCM SS # 15,877
214Texas is offline
post #15 of 272 (permalink) Old 09-18-2009, 08:39 PM
HuSSker's Avatar
I hope you have an early '95, or all that work was in vain...
'94-early '95
Late '95-'96
Yes, the manifold threads ARE different.
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
post #16 of 272 (permalink) Old 09-18-2009, 08:49 PM
214Texas's Avatar
^^^ Son of a #####. Not sure which one mine is. So if mine turns out to be a late 95 what caps are needed for those?
INC 4 Life!
95 DCM SS # 15,877
214Texas is offline
post #17 of 272 (permalink) Old 09-18-2009, 08:55 PM
HuSSker's Avatar
Well, check your check valve fittings.
If your fitting screws directly into the manifold, then you have the early style.
If it has a nut that screws onto a coupling in the manifold, it is the later one, and the cheap and easy setup for that is a pair of these from Lowe's:
They are a 5/8" flare cap, and can be had very cheap.
I'd go ahead and get the ones you ordered regardless if they fit or not, as you can usually sell them on here QUICK if they dont.
2 other indicatos of the later style:
-The passenger side has a hose that goes from the pipe to the check valve in a clumsy circle over the valve cover.
-Fuse 3 in the underhood fuse box is 25 amps as opposed to 20 amps on the older style.
'94 Impala SS
SSRI
Herter tuned
HuSSker is offline
post #18 of 272 (permalink) Old 09-18-2009, 09:06 PM
214Texas's Avatar
hard to tell in these pics but mine has the wierd looking loop back over the passenger side valve cover. But the driver side bends left like the first picture you posted and not to the right like the second picture.
Guess I will just have to wait until I get off work to definately confirm which one I have
INC 4 Life!
95 DCM SS # 15,877
214Texas is offline
post #19 of 272 (permalink) Old 09-18-2009, 09:10 PM
HuSSker's Avatar
You have the later style. Notice the passenger side hose going in a big circle over the valve cover/oil cap. That eyesore goes away when you get this deleted.
Next stop: Lowe's/Home Depot
'94 Impala SS
SSRI
Herter tuned
HuSSker is offline
post #20 of 272 (permalink) Old 09-18-2009, 09:21 PM
214Texas's Avatar
aight thanks
INC 4 Life!
95 DCM SS # 15,877
214Texas is offline
