Smog pump delete Bolts to plug exhaust manifolds? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 10-26-2010, 01:34 AM Thread Starter
Steves95SS's Avatar
Question Smog pump delete Bolts to plug exhaust manifolds?
Guys I had deleted my Smog Pump along time ago as well as had the PCM reprogrammed for it but never took off the aluminum crossover tube from one side exhaust manifold to the other. Since I recently rebuilt the motor and put it back in I want to go ahead and plug the exhaust manifolds where the tubes screwed into. So my question is where can I purchase the large Bolts to plug the exhaust manifolds? I know NAISSO superstore used to sell them but I looked and couldnt find them there. Where can I buy these? Thx Steve
95 DGGM SS, RAISS Intake, 160 Stat, TB Bypass, Descreened MAF, PCMforless Programming, Flowmasters, MSD 8.5 wires, Cowl Hood, LT4 module, 20" KMC SS Rims.
Steves95SS is offline
post #2 of 8 (permalink) Old 10-26-2010, 07:21 AM
Do a search for 'air pump delete' there are like 3 good threads on this topic. I used the jeep drain plug from NAPA referneced in one of the threads. Good Luck.
95 Impala SS, 79K, 304SS GEN II TRI-Y, 304SS CIA exhaust, tubular xmember, throttle body bypass, 160 t-stat, stealth bolts, LT4 KM, PCMFORLESS tune, Gary's cables, vette starter, 3.5MAF, RAISS, Racetronics, 55W 5000K DDM HIDs, s10 oil pressure sensor, AIR delete, Hotchkis springs/Bilstein shocks, lt4 composite valve covers.
Deceased: 96 Caprice 9C1
leak1210 is offline
post #3 of 8 (permalink) Old 10-26-2010, 02:04 PM
I used the stock bolt and cut the tube, smashed the tube closed, and folded it over and put it on my headers.
Vandalized by the ex!!!
eshaw301 is offline
post #4 of 8 (permalink) Old 10-26-2010, 02:15 PM
94MI9C1's Avatar
You could always weld them shut like I have done on my cars before headers
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #5 of 8 (permalink) Old 10-26-2010, 02:21 PM
KW Baraka's Avatar
Originally Posted by Steves95SS View Post
......So my question is where can I purchase the large Bolts to plug the exhaust manifolds......
Got mine from True Value.
I think they're 3/4"......been a long time.....
KW
KW Baraka is offline
post #6 of 8 (permalink) Old 10-26-2010, 02:41 PM
HuSSker's Avatar
The no kidding scoop on manifold plugs.
'95 cars have 2 versions of fittings. The difference is shown in these 2 pics:
'94-early '95
Late '95-'96
Notice the fittings on the manifolds. The threads in the manifold itself ARE different.
If you have an early '95, you can use these oil drain plugs that can be bought at Napa for a few bucks. I'm told the part number is BK 7041016.
http://www.napaonline.com/Search/Det...016_0282450010
If you have a late '95, you can use a 5/8" flare cap, availible at your local Lowe's.
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
post #7 of 8 (permalink) Old 10-26-2010, 03:46 PM
KW Baraka's Avatar
Originally Posted by HuSSker View Post
.......If you have a late '95, you can use a 5/8" flare cap, availible at your local Lowe's.
Yes....this is what I have on my SLP Headers......5/8" is the correct size!
KW
post #8 of 8 (permalink) Old 10-26-2010, 06:07 PM
94MI9C1's Avatar
-10 AN fitting works as well for the later years, on the stock manifolds they are the same opening they just have a fitting that converts it to a flare, you can take that fitting out and us the plug as posted above instead of the cap for a lower profile installation, but with headers they come with a flare so you have to use an AN cap or the cap that was posted above.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
