CATS & California - Page 2 - Chevy Impala SS Forum
post #11 of 46 (permalink) Old 09-17-2011, 02:47 PM
Mr pogo's Avatar
Originally Posted by BALLSS View Post
With this said a CAT from a 94-96 LT1 B body dual exhaust will work and appear "stock"
I believe the 96's have the rear O2 bungs as part of the cat outlet pipe so 94-95's wont work on 96's
Mr pogo is offline
post #12 of 46 (permalink) Old 09-18-2011, 12:13 PM
yeah, would have to weld in a 02 bung for the pre 96 year
post #13 of 46 (permalink) Old 09-18-2011, 08:23 PM
KW Baraka's Avatar
The Catco cats in the links that I posted have the O2 bungs in them. They come with a bolt in the bung for 1994/1995's.....remove the bolt for 1996.
But since they are visually identical to stock cats.....we don't need no stinking stamps !
KW
KW Baraka is offline
post #14 of 46 (permalink) Old 08-27-2013, 05:07 PM
KingsKrew's Avatar
Originally Posted by KW Baraka View Post
If they’re part #’s 9403 and 9404, then they’re direct replacements for the stock cats. Don’t sweat it. No one will be able to tell the difference. They look stock, perform like stock, etc. And yes…..if you pass emissions (even in Cali) with stock cats, then you’ll pass with these.
KW
Verified yesterday!
1996 Impala SS
1996 Caprice sold
KingsKrew is offline
post #15 of 46 (permalink) Old 08-27-2013, 09:32 PM
Dropped Fullsize's Avatar
This is the part of living in Cali that I don't miss. Florida has no smog or inspections. :-)
As a matter-of-fact, my cats went out on my dually a week ago. Cat element broke apart and created all sorts of backpressure and performance issues.
Truck is running fine now and back on the road. :-)
Dropped Fullsize
82 El Camino
95 Impala
00 Crew Cab Chevy Dually
01 300M
02 Silverado
11 Crew Cab Silverado
_______________________________________________
Dropped Fullsize is offline
post #16 of 46 (permalink) Old 08-27-2013, 10:17 PM
Powder96ss's Avatar
You can put almost any cats on, who's to say you didn't put them on in 96,97,98, etc. as long as it passes the sniffer. If you want to tell them you just put new cats on, then be prepared to have that carb e.o. # on there. I know this thread is old but, for anyone that's looking to buy from someone here and has to worry about it.
1995 WHITE B4U...SOLD
1996SSpeed DCM SS
1996 DGGM SS
WWW.theincforum.com
www.OutlineClothing.com
Powder96ss is offline
post #17 of 46 (permalink) Old 08-29-2013, 01:54 PM
In Calif the CARB (calif. air resource board) is the governing body with all the "rules" on what is allowed. Now with the "STAR" program in effect smog shops are under penality if they don't comply with wtf the CARB regulations are. Muffler shops can only "legally" replace a OBD2 CAT with the same size as stock (2 1/4 NOT 2 1/2" CATS).
Obviously some muffler shops will weld in whatever you bring in or buy from them but it is getting harder to find those as they face stiff fines if caught. CARB spends $ sending in decoy cars/agents to smog shops, it is such BS
so magnaFlo paid whatever $ to get a line of weld in CATS CARB certified which is why those are fing $200 each vs $60 for a Catco universal fit one.
Now pulling into a STAR smog shop with a modified motor lets say with headers and CAI (let alone it is a 383 H/C car) and the tech is 1st going to do visual and flag any non CARB certified componet on the car. The headers are screaming a issue to him and if he looks at the CATS and see's they are not in the position of stock ones AND then finds they are not OBD2 CARB labled (stamped in the heat shield) you are not going to pass big time regardless of how clean the tail pipe emission reads.
sooooo you can roll the dice and install the non CARB and in many cases get away with it....or maybe not
is there any diffrence between non CARB and CARB OBD 2 compliant CATS, other than OBD 2 having rear 02 bungs NO!, just the price tag
while I did have to watch the tech jack up my car, crawl underneath and look at the fing stamped in CARB/OBD2 marking and verify the headers were CARB compliant that is not the case on all shops. Just now the STAR program means that if a shop passes a car and it then fails 2 years later, he can get fined. Such BS but is why shops now just don't want to F with cars that are...let's say questionable on what modifications have been done regarding smog compliance.
the 96 OBD2 cars are the problem. OBD1 cars you can weld in the $60 CAT
post #18 of 46 (permalink) Old 08-29-2013, 02:18 PM
Mr pogo's Avatar
the thing tho is that from what I remember last I looked at my spare 96 oem cats sitting in my storage shed, they do not have any obd2 (or anything else) stampings at all.
so if kw's cat looks like oem and second O2 bung as required, all things being equal I doubt a smog shop will flag them.
Mr pogo is offline
post #19 of 46 (permalink) Old 08-29-2013, 03:02 PM
KingsKrew's Avatar
I passed with PCM tune, K&N CAI, headers, air pump delete, and (somewhat) obviously BRAND NEW Catco cats @ a STAR smog shop CA. I did however walk in to the shop with a folder full of info, including CARB/EO info printouts for all components (brought EO info for Magnaflow, better than nothing!).
1996 Impala SS
1996 Caprice sold
post #20 of 46 (permalink) Old 08-29-2013, 03:41 PM
OEM CATS did not have any markings on them. It is for "replacement" CATS manufacturers make. MagnaFlo decided to go through the CARB process and costs so they coud sell a CARB replacement. If the CATS in the car "look" stock I would bet the majority of the time there would be no issue.
It is when headers without air fittings or some other "visual" thing leads to a particular tech to look further
I suspect your diligent paperwork, albiet you don't have the magnaFlo CATS, is what did it.
I don't volunteer any info but I do have CARB stickers on car for: Headers, CAI, MSD box and even RR (although they never see those). I don't say anything about the 383 or tune. Heck it even says "manual" under transmission on my printout of smog cert.
Obviously in Kings test he passed 'tailpipe" and had enough documentation for the tech to pass visual.
it is still fing BS as what comes out of the tail pipe is what matters. The rest is political revenue making BS....but if that is the game you just need to know how to play it...and win.
