CATS & California - Chevy Impala SS Forum
post #1 of 46 (permalink) Old 09-16-2011, 06:29 AM Thread Starter
CATS & California
What's the deal with CATCO cats not being legal in Cali? I was getting ready to sell my set to a guy out there and saw on Summit's website that they're not legal.
Would these not pass a visual inspection? What are people to do if they need to replace them, buy used OEM ones from a junk yard?
Anyone know?
Black 96 Impala #159, ESE-396-CIA SSRI - AI 200cc heads & Cam -Comp 1.6 rockers -Trick Flow 36# Injectors -Hotchkis springs - Bilstein 1104/0929- BMR UCA, LCA, front & rear sway bars- PPM front end kit-Speedtech Tublar A-arms-2.5" Spintech Catback w/ 3" over the axle - CIA Gen II's - 8000k HID kit- Yank 3600 stall- 4.10 gears w/ Eaton Posi - Denny's Aluminum Driveshaft- F-body MAF- TPIS 58mm TB - Computer Tune by Brian Vorphal - FLT Level 4 trans
DarkSSide96 is offline
post #2 of 46 (permalink) Old 09-16-2011, 07:36 AM
EagleMark's Avatar
Just a guess! They do not have a CARB Certificate number making them illegal in CA.
EagleMark is offline
post #3 of 46 (permalink) Old 09-16-2011, 07:47 AM Thread Starter
So what are guys to do when they need new ones?
post #4 of 46 (permalink) Old 09-16-2011, 07:54 AM
EagleMark's Avatar
Buy an aftermarket one that has a CARB sticker or one from parts store that meets OEM specs...
post #5 of 46 (permalink) Old 09-16-2011, 02:09 PM
KW Baraka's Avatar
If they’re part #’s 9403 and 9404, then they’re direct replacements for the stock cats. Don’t sweat it. No one will be able to tell the difference. They look stock, perform like stock, etc. And yes…..if you pass emissions (even in Cali) with stock cats, then you’ll pass with these. California is just 'fummy' that way.....
http://www.summitracing.com/parts/CTO-9403/
http://www.summitracing.com/parts/CTO-9404/
KW
KW Baraka is offline
post #6 of 46 (permalink) Old 09-16-2011, 02:16 PM Thread Starter
Thanks KW.
I don't want this guy to buy these and then they not work. He only needs the passenger side and all of the part numbers for it are on the heat shield that face the under side of the car. They would need a mirror to get up there and look but I don't see why they would because it looks identical to the stock unit from underneath the car.
post #7 of 46 (permalink) Old 09-16-2011, 03:48 PM
KW Baraka's Avatar
Originally Posted by DarkSSide96 View Post
Thanks KW.....
No problem!!
KW
post #8 of 46 (permalink) Old 09-17-2011, 12:44 AM
CATS here in Calif. for cars 96 and newer (OBD2) "officially" need to be C.A.R.B. OBD2. This makes them $200 vs $60 for a generic CAT.
It typically does not happen on smog tests but I have had a guy confirm mine were stamped with the CARB AND the OBD2 for the visual part of the test.
With this said a CAT from a 94-96 LT1 B body dual exhaust will work and appear "stock"
This carb obd2 crap is about how the CAT is labled, not what the tail pipe says.
I have MagnaFlo OBD2 C.A.R.B. CATS I had welded in. They are stamped.
Name:	clutch inst 8 clutch fork.jpg
ID:	20610   Click image for larger version
Name:	clutch inst 12 slave.jpg
post #9 of 46 (permalink) Old 09-17-2011, 05:52 AM
EagleMark's Avatar
CARB Version 2 ?
You can tell how long it's been since I lived shortly in CA...
Is there a diference in a cat and a CARB OBD2 cat? Other than the sticker/stamp?
post #10 of 46 (permalink) Old 09-17-2011, 11:16 AM
mrbbody's Avatar
Originally Posted by EagleMark View Post
CARB Version 2 ?
of coarse, the price the manufacturer paid to get it certified
96 Impala SS DCM/BBB
96 Impala SS BBB
95 Impala SS DCM
94 9C1 Caprice SS clone soon to be DGGM
92 wagon........ sold
the "throw back" build thread
http://www.impalassforum.com/vBullet...d.php?t=259915
mrbbody is offline
