What are the widest tires you can fit on a stock Impala - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 01-23-2011, 10:31 AM Thread Starter
Like the title says, what are the widest tires that you can fit on the rear of a stock impala? I already am running 275's on the rear on the stock rims, but I'm looking to upgrade to 20's on all 4 corners and I want to run the widest tire possible on the rear without notching the frame. So I guess my final question is, what width wheel, backspacing, offset, etc. to run the widest tire on the back?
I tried the search function but couldn't find anything. Thanks!
pimpalass96 is offline
post #2 of 13 (permalink) Old 01-23-2011, 10:40 AM
I take it you followed instructions for at least one of the two applicable stickies right above this thread?
\'96SS SOB: SSRI, Herter Tune, Tri-Y II, SLP SS, 3000 Edge, F/HO bars, METCO extendeds, Bilsteins, currently Vredestein Ultrac Sessanta (315/35 rear)
\'96FWB BUW-Butt Ugly White: [gonna change that just as I did my last one] boxstock [yep, that's changing too]
post #3 of 13 (permalink) Old 01-23-2011, 10:53 AM
cudablack2004's Avatar
some ppl i heard use 315s 295s and i had 285/45zr17 on my 93
got rice?Import Driver Gone Domestic!
cudablack2004 is offline
post #4 of 13 (permalink) Old 01-24-2011, 02:30 AM
California Livin''s Avatar
I got the C6 rims that are 10" wide on back with 2.5" spacers. Theres about half inch before the tires stick out.
1995 Impala SS LT1 383 Stroker Daily Driver
California Livin' is offline
post #5 of 13 (permalink) Old 01-24-2011, 07:16 AM
350
350's Avatar
Send a message via AIM to 350
My 295/30/20's fit great front and back, rims are 20x8.5 +15 offset.
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
07 Wimpala
350 is offline
post #6 of 13 (permalink) Old 01-24-2011, 08:33 AM
1-CLN-SS's Avatar
315's
96 BBB with 22x11(rear)Asanti's,Pirelli 315/25/22(rear),Vogtland springs,Blistein shocks,LE1 heads,Crane 227,Crane 1.6 RR,Dynomax pipes,Magnaflows,Pypes x-pipe,K&N,BH program,Dans Gen II Tri-Y's,Hotchkis X-tend,Eaton,3.73 gears,Edge 2800 and a few hundred pounds of audio in the trunk.
DFW_INC Member
1-CLN-SS is offline
post #7 of 13 (permalink) Old 01-24-2011, 01:30 PM Thread Starter
Thanks for all the input. This should help out, along with the stickies in the beginning of the page.
post #8 of 13 (permalink) Old 01-24-2011, 01:57 PM
94MI9C1's Avatar
315's on mine
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #9 of 13 (permalink) Old 01-24-2011, 02:11 PM
Mean SS's Avatar
Send a message via AIM to Mean SS
Mean SS is offline
post #10 of 13 (permalink) Old 01-24-2011, 03:05 PM
That said, I run 1 1/2" widened oem wheels and 315/35 on my BBB. FTR I'm sure everyone knows;
1. Caprice/9C1 do not use exactly the same axle as the SS
2. And my SS setup will NOT bolt to my FWB as the rear is either narrower, or, the frame is slightly wider.
