What's the widest 15" wheel/tire I can fit on my box Caprice? - Page 2 - Chevy Impala SS Forum
post #11 of 25 (permalink) Old 12-09-2011, 05:42 AM
Moderator
Firewood's Avatar
Originally Posted by Barbarossa View Post
Hello,
someone may be along that is able to answer this, but ImpalaSS Forum is mostly about 94-94 Impala SS's.
Say no to donks.
A Box is not a Donk.
_______________________
Firewood is offline
post #12 of 25 (permalink) Old 12-09-2011, 06:59 AM
SuperSport's Avatar
It (as well as a 6th gen) can be voted as one if it's lifted like a 4x4, sitting on 26" wheels, with a paint scheme like a rolling skittles, m&m's, Lowe's, mighty mouse or jolly rancher billboard!
On the opposite, a Box can look just as clean as a 6th Gen... if kept tastefully clean. BUT... different strokes for different folks! To each his/her own. No two people are the same.
Have a nice day!
-SuperSport- ISSCA #2476
'95 Impala SS (#1,245 of 18,365) --- It's alive, but not quite complete... SLOW PROCESS!
SuperSport is offline
post #13 of 25 (permalink) Old 12-09-2011, 07:05 PM
loweredd's Avatar
285/40/18 on an 18x10" with a 5.5" backspace, and it tucks.
79 Impala 4dr-Undergoing LS1/4L60E/Turbo swap-Airride#
89 Caprice Wagon-LQ4/4L80E swap#
loweredd is offline
post #14 of 25 (permalink) Old 03-29-2012, 09:15 AM
Any pics box caprice 15x10 5,0 bs wheel and 295/50-15 tires?
FinnChevy is offline
post #15 of 25 (permalink) Old 05-02-2012, 04:04 AM
No 295/50-15 pics?
post #16 of 25 (permalink) Old 05-02-2012, 07:59 AM
Many confuse backspace,and offset. Offset is always referencing the wheel centerline either +,or- Backspacing is the distance from the inside bead to the mounting flange. The example given of a 15x10 with 5" backspace would have a "zero" offset. The mounting flange is in the center of the wheel. If there's a choice between slightly different backspace,go with the smaller. You will always be able to move tire/wheel out with a spacer,but you can't bring it in if it's out a little to far.
post #17 of 25 (permalink) Old 05-02-2012, 11:47 AM
Hilpala SS's Avatar
Send a message via AIM to Hilpala SS
Have a nice day!
False. LOL....but I get the common misconception.
Hil Was Here...
Originally Posted by ProTools4 View Post
at some point a large overlap high compression motor with long tubes is going to shake & make so much sound that all metal spherical suspension noise transfer is another musician in the symphony of "Hot Muscle Cars Rule" in B minor
Hilpala SS is offline
post #18 of 25 (permalink) Old 12-01-2012, 08:53 PM
does anybody know if a 28/10.5.15 would fit on stock 9c1 wheels and fit on the car without rubbing or will they be to big??My car is a 89 caprice
Shttn89 is offline
post #19 of 25 (permalink) Old 12-03-2012, 08:36 PM
Don't you mean "go with the larger" backspacing?
akio is offline
post #20 of 25 (permalink) Old 12-03-2012, 09:02 PM
What's the widest 15" wheel/tire I can fit on my boxy
The greater the backspacing,the further in the tire/rim will be. As I mentioned before,the tire/wheel can be moved out with spacers. Most steel wheels are neutral,or close to it. I did fit a 275/60 on a 15x10,and I suspect a 295/50 would have fit also. Long story short, I meant greater. This is one reason I dislike using backspacing figures,I find offset specs much easier to use.
