New Calipers - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 01-17-2012, 03:58 AM Thread Starter
Don.V's Avatar
New Calipers
Had to buy a new brake caliper for passenger rear, do I have to install new
brake pads as well? Do I have to bleed the brakes too?
Don.V is offline
post #2 of 5 (permalink) Old 01-17-2012, 04:01 AM
I don't know about the pads. If it were me I'd replace them,(both sides) but definitely bleed them.
kingofkentucky is offline
post #3 of 5 (permalink) Old 01-17-2012, 08:15 AM
SimplyTheBeSS's Avatar
don't need to use new pads if they are in decent shape but you HAVE to bleed them. Air in your brake system can make your pedal go to the floor with no brakes. You don't want that! (Neither does the guy in front of you!)
Also have you installed the brake bolt mod? I'm just wondering if your rear brake calipers never came on before and that is why they needed to be replaced. Probably one of the cheapest and best modifications you can do to your car (Assuming it's a Impala and not caprice but since you have a rear caliper I'm assuming you have an impala or a caprice with rear disc brakes)
1994 SS
SimplyTheBeSS is offline
post #4 of 5 (permalink) Old 01-17-2012, 04:46 PM
Lukes86's Avatar
does anybody have a schematic of how the brake system works on a 4 wheel disc brake Impala
After the 2 lines exit the master cylinder
Lukes86 is offline
post #5 of 5 (permalink) Old 01-18-2012, 07:40 PM
SEO9C1's Avatar
New pads would be best, but really depends on how much is left on the old ones. I'd just do it for piece of mind. You should check the condition of your soft brake lines as well. You will need to bleed the brakes. It's been mentioned to you many times already and no matter how many times you ask, the answer won't change.
Read this:
Another brake overhaul thread
Particularly I.), A.) 1 and 3 thru 21 & I.), B.) 1 thru 7 & III.), A.), B.) & C.).
SEO9C1 is offline
