Hello. I have a question. I purchased a new set of mirrors off ebay and tried to connect them and I cant get them to fully function. What Im saying is I can get the drivers side one to go left and right and the passenger to go up down and left. NOTE: I cut the wires before by the kick panel. There are 8 of them. I connected the wires every which way I possibly can think and the best I could come up with is what I said in the beginning.
Main Question: Do after market mirrors have some different wiring? Do people have problems with them needing extra wiring to make them work? Or, am I doing something wrong and have something not right. Anybody have a link to a wiring diagram? Thanks.
Everytime I get close and make a change in the wires (same colors of course swapping whites for whites) it does something worse. There are two purple wires coming off the little ball switch and two of every other color totaling 8 wires. Need some advice. Does the FSM have any helpful info?
Thanks
NOTE: When I had all the wires connected the best I thought (all colors matching), I took the passenger side panel off to test the plug with a test light. It sends the signal to the mirror and I see the same signal send to the drivers side door wiring area, but the passenger mirror dont move right. Could this be a ground elsewhere and I have things correct? I remember cutting the wires because there was too much wire down there (I wanted to minimizesome) and I damaged my drivers mirror backing in to a carport. I have not been able to get the mirrors going ever since.
Thanks
