replaced rear turn signal bulbs and now they dont blink........ - Chevy Impala SS Forum
post #1 of 34 (permalink) Old 01-14-2011, 08:20 PM Thread Starter
9SEA1's Avatar
so i replaced the rear turn signal bulbs in my 96 caprice with LED bulbs. now my front turn signals will come on when i hit the blinker but not blink and i see no change in my rears when i hit the blinker or hit the brakes. any suggestions??? blown fuse?? i have no idea. where is the fuse location for the turn signals?
9SEA1 is offline
post #2 of 34 (permalink) Old 01-14-2011, 09:48 PM
94MI9C1's Avatar
Typical problem with LED's, you need to install a "no Load" flasher for them to work. Typical flashers are thermal flashers and require a load to make the internals work, if you don't have the resistance of the bulbs there it won't work. I do believe this one will work for you but can't be certain
http://shop.advanceautoparts.com/web...S_612665743___
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #3 of 34 (permalink) Old 01-14-2011, 10:26 PM
Mr pogo's Avatar
that one wont work. you need the led flasher like grote makes, 2 terminal with separate ground wire.
plus a second flasher for the four ways.
if you just do the rears thats all you need.
if you do the fronts also you'll have to add load resistors to the fronts as 100% leds arent enough even for a led flasher.
also the front outer turn signal/parking light bulb is not convertible to leds without further mods.
I just finished the outside lights to 100% led, might do a thread on whats required.
Mr pogo is offline
post #4 of 34 (permalink) Old 01-14-2011, 10:28 PM Thread Starter
9SEA1's Avatar
How do they work/what do they do? Where does it go? And where can I get them? Sorry for so many questions.hahaha
9SEA1 is offline
post #5 of 34 (permalink) Old 01-14-2011, 10:31 PM Thread Starter
9SEA1's Avatar
I replaced the 1156 bulbs for the rears only. The inner and outer ones on the top.
9SEA1 is offline
post #6 of 34 (permalink) Old 01-14-2011, 10:43 PM
Mr pogo's Avatar
well Im at work and info is at home.
Ill see about pics too.
Mr pogo is offline
post #7 of 34 (permalink) Old 01-15-2011, 01:50 AM Thread Starter
9SEA1's Avatar
Coo thanks man
9SEA1 is offline
post #8 of 34 (permalink) Old 01-15-2011, 05:26 AM
Mr pogo's Avatar
ok Im having a brain fart cause its late but heres what I remember when I just had the rears changed to leds.
I only ran that for a week or two before changing everything to led which opened more cans of worms but thats another story.
the led flasher that fits a b body is the grote 44891, two terminal with a third wire that is attached to ground.
under the fuse box where the flashers are there is a predrilled hole perfect for ground using a sheet metal screw.
napa sells them, not sure if az does.
I believe I used one led flasher for the turn signals and one of the leftover stock flashers for the four ways.
the two stock flashers are different from each other because of more amp draw with the four ways so try each of them to see which one works.
hope this helps
Mr pogo is offline
post #9 of 34 (permalink) Old 01-15-2011, 03:44 PM Thread Starter
9SEA1's Avatar
Awesome! Thank you, Ive never put these in before and was lost. The autoparts stores we got up here are O'Reilly autoparts. I'll have to check otherwise I'll have to order them. Thanks again!
9SEA1 is offline
post #10 of 34 (permalink) Old 01-18-2011, 10:01 AM
jonhpc's Avatar
walmart carrys an electronic flasher as well
-92 ltz, T5 trans, R.I.P. 4/19/13
-94 9c1, sprints with 22's
-96 civi, the "behemoth"SOLD
-93 Fleetwood, SOLD
............FLA INC..............
jonhpc is offline
