automoter water temp!!! - Chevy Impala SS Forum
post #1 of 48 (permalink) Old 02-20-2011, 11:21 PM Thread Starter
1real95SS's Avatar
Exclamation automoter water temp!!!
as i read all water gauges go bad in the impala and the sensor on the front by the water pump is for the pcm. i have a auto-meter gauge ready to install but need to know if i tap into the wire on the RH side of the block will my gauge read??
1real95SS is offline
post #2 of 48 (permalink) Old 02-21-2011, 12:23 AM Thread Starter
1real95SS's Avatar
anybody? Ive ran everything but the sender wire and ground. where can i tap into??
post #3 of 48 (permalink) Old 02-21-2011, 12:30 AM Thread Starter
1real95SS's Avatar
or do i have to use the sending unit that came with the gauge?
post #4 of 48 (permalink) Old 02-21-2011, 02:13 AM
Pretty sure you have to use the unit that came with the gauge.
Maybe remove the pipe plug from the driver side head and tap into it there?
I wouldn't mess with the WP sender though.
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
BigB9000 is offline
post #5 of 48 (permalink) Old 02-21-2011, 07:52 AM
94MI9C1's Avatar
I don't know where you read that all temp gauges go bad, they are no more prone to failure over an Autometer gauge to be honest, most from what I can gather put one in for better accuracy.
As stated above DO NOT splice off the temp sender on the water pump, leave it alone.
If you aren't going to use the factory gauge just takeout the original sender on the passenger side and put in the new gauge sender. I really don't think that there is any difference in the senders to be honest, pretty sure all manufacturers use the same sender specifics.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #6 of 48 (permalink) Old 02-21-2011, 08:18 AM Thread Starter
1real95SS's Avatar
NOOOO i wasnt talking about tapping into the WP sensor i was reffering to the one on the passanger side.
as far as the gauges going bad, ive read countless threads of people saying they have been thru the same issue weather it was the sensor, gauge etc... seems common in these cars to have temp fail.
but as u stated ...
i should unplug the one wire sensor on the passanger side of the block... and replace the new sender there?
post #7 of 48 (permalink) Old 02-21-2011, 08:39 AM Thread Starter
1real95SS's Avatar
DID I MENTION I HAVE THE ELECTRIC GAUGE AUTO METER ... it came with two fittings such as these
post #8 of 48 (permalink) Old 02-21-2011, 09:53 AM Thread Starter
1real95SS's Avatar
anybody??
post #9 of 48 (permalink) Old 02-21-2011, 11:38 AM
94MI9C1's Avatar
Yes
remove old put in new, I still think that you can use the old sender, but I am not entirely sure on that one.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #10 of 48 (permalink) Old 02-21-2011, 01:21 PM Thread Starter
1real95SS's Avatar
Originally Posted by 94MI9C1 View Post
Yes
i figured it out. was fairly easy. thanks!
