Turn Signal Stuck ?? - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 03-24-2012, 10:51 PM Thread Starter
Coolwazabi's Avatar
So I just got doing the hockey puck mod "which is breezy" and when it drive it around and suddenly my right turn signal is stuck. The light come on but it doesn't flash. The hazard lights work just fine along with the left turn signal. Ideas ?
Flowmaster 50 Series w/ 4" Tips
DDM Tuning 55w 5000k HID's
15" Custom Audioque HDC3, 35hz
2x Audiopipe 1800d's
Kenwood KDC-X996
Big 3 Upgrade
5901 Viper Alarm w/ Remote Start
1995 Chevy Caprice 4.3L L99
Nashville
Coolwazabi is offline
post #2 of 13 (permalink) Old 03-24-2012, 10:59 PM
The Fooser Guy's Avatar
On the interior side of the firewall (inside the car), about where your left foot sits (but up a little higher) are two, round, silver relays (about the diameter of a half-dollar). Pull them out and push them back in.
Try the turn signals.
If that does not work, swap the relays and see if the problem goe to the left turn signal.
If it does, replace the defective relay (car parts store).
HTH
The Fooser Guy
The Fooser Guy is offline
post #3 of 13 (permalink) Old 03-25-2012, 02:15 PM
AZ Roadmaster's Avatar
Take the hocky puck out, turn it 1/4 turn and re-install it, this should fix it!
[/SIGPIC]92 RMS, daily driver, project car, Eibach springs, Bilstein shocks, BMR rear upper and lower control arms, BMR front and rear sway bars, Dick Miller braces, Spohn spherical ft end links, fabricated ft sway frame support, ROH wheels with Nitto tires, replaced upper and lower control arms and all steering linkages and reman box. reprogramed ecu, tb spacer, adj. fp reg, cold air intake, electric fans, pully kit, SS rear with posi 3:73's Next big brake kit!
AZ Roadmaster is offline
post #4 of 13 (permalink) Old 03-25-2012, 03:11 PM Thread Starter
Coolwazabi's Avatar
Pulled both 1 out then both worked. Switched them and then none worked. There both different. Any idea what the model is suppose to be?
Kenwood KDC-X996
Big 3 Upgrade
Nashville
post #5 of 13 (permalink) Old 03-30-2012, 02:11 AM
shudahadaV8's Avatar
I think that one is for the turn signals and the other is for the emergency hazards and I don't remember which is for which, but if you pull one then the other you can quickly tell. I have a 95 "B" and always thought that both left and right turn signals share a single flasher (can't turn both ways at once). So if the one side flashes and the other doesn't ... well, that's odd. Turn signal switch ??
shudahadaV8 is offline
post #6 of 13 (permalink) Old 04-28-2012, 10:06 PM
cavav8r's Avatar
HTH
nice!!! had the exact same problem (no hockey puck mod though) right turn signal sticks. swaped the relays and they both worked fine. here's the interesting part though. after swapping the hazards still work, but flash fast now. doesn't matter though, just glad it did the job! thanks guys!!!
'96 SS
250,000 Miles
Engine/Tranny replaced at 200,000
DO NOT BUY A JASPER MOTOR!!!!
Interior replaced at 180,000
cavav8r is offline
post #7 of 13 (permalink) Old 04-28-2012, 11:08 PM
SimplyTheBeSS's Avatar
Fooser is the smartest Guy I know!
1994 SS
SimplyTheBeSS is offline
post #8 of 13 (permalink) Old 04-29-2012, 02:12 AM
4x4high's Avatar
When a flasher goes bad the lights will either not blink at all or they blink super fast and i've seen the same thing when a bulb is bad (although if you checked the bulbs with either the turn signal or e-flasher and they worked it's not a bulb).
4x4high is offline
post #9 of 13 (permalink) Old 10-18-2013, 05:43 PM
Biglou's Avatar
I did all this already now the problem is the green arrow turns on with headlights only the drivers side and still doesn't blink
Biglou is offline
post #10 of 13 (permalink) Old 10-18-2013, 06:03 PM
coltonx3's Avatar
i use the same flasher for the hazard for my turns it makes them blink faster i like it
95 9c1 dggm
straight black pvc kn filter
spintech pro street mufflers
most of trim and grill painted black
150k running strong and going
coltonx3 is offline
