Weekly Mods Thread... - Page 193 - Chevy Impala SS Forum
post #1921 of 1930 (permalink) Old 09-03-2012, 04:47 AM
Mr pogo's Avatar
well I wore out my index finger yesterday spraying with sem, today screwed up on the trans pan adapter so I fixed a missing swaybar endlink and redid the speedhut gauge harnesses before they get installed under the dash pad.
Mr pogo is offline
post #1922 of 1930 (permalink) Old 11-26-2012, 06:55 AM
93capriceltz's Avatar
Roadmaster Rear Door Light Mod
Did the Roadmaster Rear Door Light Mod this weekend (with LED's of course). Changed the lenses in the fronts to match as well.
Name:	Rear Door before Roadmaster Light.jpg
ID:	26665   Click image for larger version
Name:	Rear Door after Roadmaster Light.jpg
ID:	26666   Click image for larger version
Name:	Roadmaster Rear Door Lights - Side View.jpg
ID:	26667   Click image for larger version
Name:	Rear Door Inside View.jpg
1993 Caprice LTZ / LS:
51,000 miles, L05, 3:08 Posi, Harris Prom, Lowering Springs, Bilsteins,
96 Steering Wheel, 9C1 Hoses, Dual Snorkel Intake,
SS Rear Disks, J55 Fronts, High Flow Cats, Dual Exhuast, Fleetwood Horns and Center Console, Roadmaster Rear Door Lights, LED Interior
1992 Caprice Wagon: Black Sapphire/Silver, L05, Tow Pack, 3:23 Posi, 9C1 Cluster, 96 Steering Wheel, Fleetwood Horns, LED Interior
1996 9C1 - Former Whelen Trade Show Car - SOLD
1994 SS - SOLD
1991 9C1 - SOLD
93capriceltz is offline
post #1923 of 1930 (permalink) Old 11-26-2012, 11:02 AM
st95ss's Avatar
Thumbs up
see you are real handy bruh, keep us posted, looking good
looking good man
95 DCM Impala SS, G2 Cold Air Induction,G2 power pulley kit w/ v-belt ,G2 throttle body plate, G2 air foil,G2 Valve Cover Breather,pcmperformance tune, 160 thermostat,Borla Full Stainless Steel Exhaust, tri-y headers, 12 way Bonnie, air pump delete, 91 Caprice tailights SSittin on TIS 06's 22's
# 3,683 of 18,365
http://www.cardomain.com/ride/229728...ellville-ga-us
st95ss is offline
post #1924 of 1930 (permalink) Old 11-27-2012, 09:09 AM
sonuvah's Avatar
Not sure if your dash is still dismantled, or if this wizard is still making Impala pieces, but you may want to check out the link for panel display upgrades. I think he offers some pretty nice, unique pieces. I've done business with him and he's reliable. Nice work on the harness upgrades. Didn't realize there was an issue there. I was aware the OEM battery cables suck.
http://zzrstudio.com/Impala_SS.html#GT_pics
"Monk in Training"
sonuvah is offline
post #1925 of 1930 (permalink) Old 11-27-2012, 02:42 PM
Mr pogo's Avatar
thanx man!
the harness's weren't for the stock gauges but for the two speedhut pillar gauges I added.
instead of going under the lower dash to tie into the necessary power/grnd/lighting wires I found with the dash pad off everything I needed was easily spliced into at the fuse panel and light switch wiring.
Mr pogo is offline
post #1926 of 1930 (permalink) Old 06-30-2013, 05:15 PM
AlabamaSS_251's Avatar
Finally got around to installing just the rear drop springs.
Name:	ImageUploadedByAG Free1372630407.996358.jpg
ID:	43130Click image for larger version
Name:	ImageUploadedByAG Free1372630422.327395.jpg
ID:	43138Click image for larger version
Name:	ImageUploadedByAG Free1372630444.090113.jpg
ID:	43146Click image for larger version
Name:	ImageUploadedByAG Free1372630461.884872.jpg
ID:	43154Click image for larger version
Name:	ImageUploadedByAG Free1372630481.751774.jpg
AlabamaSS_251 is offline
post #1927 of 1930 (permalink) Old 07-15-2013, 12:46 AM
el_demonio's Avatar
Installed some rear door panels with courtesy lights.
Originally Posted by Lil Moco
Cold Coronas, I Got Cold Coronas! 🍻🍻
95 Impala SS -82k-Custom
94 Caprice L99 SS project-132k-Sold
95 Caprice L99 SS clone -80k LT1 swap-Sold (best car I ever owned)
el_demonio is offline
post #1928 of 1930 (permalink) Old 11-27-2014, 12:52 PM
Originally Posted by GeorgiaBoy03 View Post
Shaved my taillights smooth with plastic bumper filler and body filler,primed over it with black urethane primer and tinted the taillights bright red.
Can you provided some info on how you shaved the 9c1 tails?
post #1929 of 1930 (permalink) Old 11-27-2014, 08:34 PM
udownwitk's Avatar
Send a message via AIM to udownwitk
Sadly, he is no longer with us... RIP Joe Joe. we miss you bro!!
1996 Impala SS 121K miles: Gen II Tri-Y's, No Cats, Yukon 3.73 w Auburn Pro, bored 52mm TB w/ Air Foil/Bypass, Spintech ProStreet 6000, 8.5mm MSD wires, Delco Plugs, C3Fab Extended Arms, Vogtland springs, Bilsteins, AIR Delete, PCMforless Tune, LT4 KM, Hypertech 160* stat, Viper Alarm, Impala #31,960 Built: 9-13-96
udownwitk is offline
post #1930 of 1930 (permalink) Old 11-27-2014, 10:19 PM
SLIM•B's Avatar
Speaker upgrade
Got rid of the stock 4x6 and upgraded to 6.5 components new 6x9s and new 4 Channel all Rockford Fosgate. Made the template's for the 6.5s.
ID:	102346   Click image for larger version
ID:	102354   Click image for larger version
ID:	102362   Click image for larger version
96 Caprice 9c1 bagged lambo doors 24s(SOLD)
92 Caprice L03 white on white custom system 24s(SOLD)
96 Caprice L99 24s (SOLD)
96 Caprice L99 DGGM Impala clone dropped custom system 24s (SOLD)
94 Caprice B4U custom system lifted 26s(SOLD)
96 Impala SS DGGM on coil overs
SLIM•B is offline
