how to open headlights? - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 03-31-2010, 08:38 AM Thread Starter
96ImPaLa*BLING*'s Avatar
Send a message via AIM to 96ImPaLa*BLING* Send a message via Yahoo to 96ImPaLa*BLING*
i had a halogen bulb explode inside of my ST clear headlights... how do i open them to clean the residue on the inside? i heard about putting them in an oven but im not sure the tempurature or how long. any input would be appreciated
1996 BBB Impala, 2" cowl hood, stock rims plated in chrome,
flowmaster 40 series mufflers,2 1/2" pipe, O/R X pipe, home-made CAI, Hypertech PP3,
Motive 3.42's, Eaton posi, brand new LT1
http://cardomain.com/ride/3065975
96ImPaLa*BLING* is offline
post #2 of 12 (permalink) Old 03-31-2010, 08:48 AM
96dreamss's Avatar
Send a message via Yahoo to 96dreamss
or u can use a heat gun but look on the tread that says halo rings on it and it a video that tell u on the last page
Don't Watch Me Watch TV Its Safer..[IMG]
96dreamss is offline
post #3 of 12 (permalink) Old 03-31-2010, 08:48 AM
GA95DCMSS's Avatar
Send a message via Yahoo to GA95DCMSS
I use a heat gun and a screwdriver. Move the heat gun around a section at a time, prying between the lens and the body with the screwdriver. Once wide enough, stick another screwdriver in there to hold it open as you move to the next section.
Quentin-1995 Impala SS-. New PB coming soon
GA95DCMSS is offline
post #4 of 12 (permalink) Old 03-31-2010, 09:27 AM
Midnight's Avatar
250 deg for 10 min check then put back in if wont come apart.
Midnight is offline
post #5 of 12 (permalink) Old 03-31-2010, 10:44 AM
bigblackss's Avatar
headlights in the oven on the its lowest heat setting and for less than ten minutes usally works for me
bigblackss is offline
post #6 of 12 (permalink) Old 03-31-2010, 11:46 AM
IMPALASS_RIDER's Avatar
Send a message via AIM to IMPALASS_RIDER Send a message via Yahoo to IMPALASS_RIDER
little homie BLING is back!!
'95 DCM < unladylike *been down since jan 17th 2010*
'95 DGGM 383, 100 shot *RaceCarWithAC*
2013 F250 LIFTED on 37's
2012 Accord
'95 BBB SOLD
IMPALASS_RIDER is offline
post #7 of 12 (permalink) Old 03-31-2010, 08:45 PM
When we had to fix her Grand Marquis lens, she put a hose to the vent while leaving the bulbs in to pressurize and it popped open.
She used 4 psi, but started off with a couple. And do wrap a towel around the lens in case it blows.
cheap stuff :
yellow coolant, 160stat, key fob, sewer pipe, tb bypass, air pump delete, 91 tails, pass rear window sag, rusted caliper pins
not so cheap : heater core, radiator, water pump, carpet,
driver side door switches, stock radio, black switch panels, clear corners, oil cooler hose
expensive :
2-tone seat covers
SEM gray 15393 : Duplicolor DGGM DSGM436 or WA9795
CandiSS is offline
post #8 of 12 (permalink) Old 03-31-2010, 09:05 PM
BYB_CUZ's Avatar
I got some open with a flathead and blow dryer, I do want to know how people seal them back though.....
09 G8 GT, lets just say modded
95 b4u- basically sold sadly
2009 jeep cherokee- sold
2014 grand cherokee
BYB_CUZ is offline
post #9 of 12 (permalink) Old 03-31-2010, 09:07 PM
BYB_CUZ's Avatar
i wouldnt do the oven method, too dangerous, i had a bad experience. Blow dryer/heat gun easier to control and easier to work with.
2014 grand cherokee
BYB_CUZ is offline
post #10 of 12 (permalink) Old 03-31-2010, 10:48 PM
bigblackss's Avatar
re-heat the existing glue and clamp the lense and housing. or add some clear rtv slicone at the seam for more sealant
