how to remove the fender? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 11-15-2010, 12:56 PM Thread Starter
defdaboss's Avatar
i seen alot of bolt around there. the hood, the wheel well, the radiator support bolt, inside the door area, etc. etc.
i want to delete the antenna. i did a search and nothing came up. anybody?
(95 caprice classic tow package! 3.73, 1.6RR, beehive springs, HOTCAM, airbox delete, K&N air filter, removed mechanical fan and install electrical fan, tuned
defdaboss is offline
post #2 of 6 (permalink) Old 11-15-2010, 01:18 PM
WwWdotanthony92's Avatar
heres one thread, ill search for the others i have saved
fender removal
heres the better thread with some pics
Help a Newb remove a Door and Fender
'92 Caprice Classic
WwWdotanthony92 is offline
post #3 of 6 (permalink) Old 11-15-2010, 05:19 PM Thread Starter
defdaboss's Avatar
im extremely tired from the body work. i also need to buy a mask cuz inhale **** i could start feeling it. to pull all that bull**** to get the fender out aw lawd....
post #4 of 6 (permalink) Old 11-15-2010, 05:24 PM
Baby-D's Avatar
Baby-D is offline
post #5 of 6 (permalink) Old 11-15-2010, 07:37 PM
You can remove the antenna without removing the entire fender. You can then weld a patch over the hole and clean it up. To remove the antenna, loosen the bolts that hold the wheelhouse to the fender, and body (behind the tire), block the wheelhouse away from the fender and remove the 10 mm bolt in the doorjam. The bezel, electrical connector and the antenna lead, are next and you can pull it out of the bottom. You can avoid all the hassle of realigning the fender.
Fred Kiehl is online now
post #6 of 6 (permalink) Old 11-15-2010, 08:51 PM
383LSxIMPALA's Avatar
[QUOTE=Fred Kiehl;2428602]You can remove the antenna without removing the entire fender. You can then weld a patch over the hole and clean it up. QUOTE]
thats what i did!
2006 ram 2500 4x4 crew cab long bed. billet inglewood trans. s366 turbo. efi live. twin cat stacks. stock fueling 8.58@82.56 at over 8500lbs
383LSxIMPALA is offline
