rustoleum roll on paint job - Page 2 - Chevy Impala SS Forum
post #11 of 21 (permalink) Old 09-12-2011, 03:41 AM
SEOK's Avatar
Nice job!
I did this about 3 yrs ago to a white 85 Imp we had. still looked nice the last time i seen it about 8 mths ago. I think the real key is to make sure you use 100% mineral spirits. and thinned it to just between water and milk consistency, for some reason it seems to allow the paint to lay down real flat while its evaporating. I did 2 coats, light wetsand 600, 2 coats, light wetsand 800, and finished with 2 coats. orange peal was MIA
dont worry about how well you lay down the first couple coats, just lay it down. the last ones will take care of anything funky. and expect it to be transparent thru the first 3-4 coats. take your time, one panel at a time.
if it gets alot of bubbles after layin a coat down just LIGHTLY roll over them with just the weight of the roller. dont worry about it looking glass instantly, as it sets it flattens alot.
it was actually a fun lil project. plus if you ever get a ding or scratch its easy to fix and just roll the section again!
used-
Rustoleum
4" high density rollers
and typical body/paint supplies.
95 CAPRICE B4U WHT (SOLD)
6000K HIDs, LEDS, Steelies/Chromed caps W/ Coopers, Grey Bonnies, Gary's Wires, TB bypass, Air Pump delete, CAI, Dual Elec fans
68 BUICK SKYLARK 2D HT--2nd owner, all original, rust free 350/th350, almost ready for paint!
79 Eldorado Biarritz White on White, factory Olds 350
SEOK is offline
post #12 of 21 (permalink) Old 09-12-2011, 03:44 AM
SEOK's Avatar
Sucks that rustoleum dont sell a clear in non aerosol form in the US. in canada the Rustoleum equivalent is a brand called Tremclad that DOES sell a clear that can be rolled. would be interestinmg to see how it would look with a clear rolled on wetsanded/polished.
SEOK is offline
post #13 of 21 (permalink) Old 09-12-2011, 04:24 AM
Originally Posted by Nashsurecanpaint View Post
With my knowledge of auto body and paint I see no reason this wouldn't work. The only real difference is the texture you'd have after painting. The roller may leave a rougher "orange peal" but with a little sanding and buffing ANY orange peal can be sanded flat and buffed out. I may try this soon and post my results (pictures).
Even when it is sprayed on it still has the crappy texture.
I have done it 3 times
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
BigB9000 is offline
post #14 of 21 (permalink) Old 09-12-2011, 06:37 AM
A lot of good info here:
http://rolledon.forummotion.com/
All sorts of combinations of paint, reducer/thinner, hardeners, tools, techniques, etc. have been tried.
crerus75 is offline
post #15 of 21 (permalink) Old 09-12-2011, 07:50 PM
When I was in college in the 60's, a friend painted his 1946 Pontiac fastback with a BRUSH. No prep, no tape mask, etc and it looked it.
But it ran well and got us where we wanted to go.
BTW - he is now a Federal judge.
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
grandpas wagon is offline
post #16 of 21 (permalink) Old 09-13-2011, 07:59 PM
Sinister's Avatar
There are some insane projects on that link you provided.
1995 Caprice Wagon
Sinister is offline
post #17 of 21 (permalink) Old 09-13-2011, 08:37 PM
96louD_paC's Avatar
Thumbs up
wow that car looks better than my 9c1
looks good....hoping for my "flat grey rattle can" looks as good lol
DC INC
"desert storm" 94 caprice 9c1 5.7
"louD_paC" 96 caprice 9c1 5.7
"BLACK STALLION" 96 caprice 4.3 DD
96louD_paC is offline
post #18 of 21 (permalink) Old 09-13-2011, 09:50 PM
cuchullainn350's Avatar
The white is rustoleum gloss white, sprayed, thinned with mineral spirits. The metal flake was added to clear coat. I waited 2 weeks to make sure the paint was fully cured, then I hit it with 800 grit before spraying any clear coat. All in all, I probably have about $250-$300 in the paint itself. If you count a few odds and ends, like a PC dual-action, a couple tarps, etc. I'm still below $600. Lucky me, I have an Air compressor and a few nicer paint guns.
If you are going to go the rustoleum route, go to Tractor Supply and pick up some Valspar Enamel Hardener. This will make the paint dry faster and harder. Without it, Rustoleum will never "really" dry.
My reason for going cheap is simple. The car has ALOT of rust hidden under all the chrome. It was a cheap car purchased as a DD. It is, for all intents and purposes, a Rat-Rod. I give it 3 maybe 4 years until it will be beyond saving. But I have alot of fun in this car, and get nothing but compliments. Plus, it sparkles like the bass boat I can't afford. Not the best way to paint a car, but it works, and it will look good if you put time into it.
ID:	20556   Click image for larger version
1994 Slicktop Fleetwood. I painted it and did a few other things
cuchullainn350 is offline
post #19 of 21 (permalink) Old 09-18-2011, 04:18 PM
Jaymz's Avatar
Looks good. Real good. I did the flat black treatment to my wagon a few years back. I wasn't trying to give it a show room shine. I didn't put a whole lot of effort into it. I may have to try this on a future project.
1996 ImpalaSS Suncoast Ram Air Hood w/SSRI, March power pulley set, 3:73 gears, eaton posi, 2500 stall TC, Indash 6.5\" Clarion TV/DVD/NAV, 6.5\" Diamond audio comp. front and rear, 20x10 KMC Novas front and rear.
Jaymz is offline
post #20 of 21 (permalink) Old 09-28-2011, 10:20 PM
neo-havock's Avatar
Cars were painted in a similar fashion well into the 30's. And many "Hotrodders" use this technique into the 60's. And the sand, polish wax method or "(hand) Rubbing" is still in use today at any shop worth it's spit.
1996 Chevrolet Caprice SEO 9C1, sold
neo-havock is offline
