Hood Latch Question - Page 2 - Chevy Impala SS Forum
post #11 of 24 (permalink) Old 03-02-2012, 01:12 PM
Hood Latch Question
When mine wouldn't open I stuffed a rag between the grill,and bumper pad. This created enough upward pressure to pop the hood when I pulled the lever.
post #12 of 24 (permalink) Old 03-21-2012, 11:11 AM Thread Starter
chi-town 9c1's Avatar
Originally Posted by Fred Kiehl View Post
You can remove the grille on all the cars. You need a torx 20 or 25.
once you remove grille then??
There's a reluctance to confront reality and a desire to soften unpleasant realities
chi-town 9c1 is offline
post #13 of 24 (permalink) Old 03-21-2012, 11:41 AM
GoldSSWagon's Avatar
PM sent
1995 Gold Caprice Wagon
1991 White Caprice Wagon SOLD
1991 Olds Custom Cruiser Wagon Sold
1995 RMW under construction
2004 Impala SS
2012 Chevy Terrain SL2
1974 BD-5T WIP SOLD
GoldSSWagon is offline
post #14 of 24 (permalink) Old 03-21-2012, 12:27 PM
supergreedy287's Avatar
you dont need to take the grill off . lay on the ground in front off the car . use your hand to feel around the latch . You will feel a lever or a switch , push to the right . Hood will pop right up . Surprised the s hit out of me when I had the same problem .
96 Impala SS BBB vortech v1 supercharger 112k mi.
07 Escalade Black on Black 75k mi.
supergreedy287 is offline
post #15 of 24 (permalink) Old 03-21-2012, 03:49 PM Thread Starter
thanks GoldSSWagon got it but now the little thing the cable sits in popped off
post #16 of 24 (permalink) Old 03-21-2012, 04:21 PM
Hood Latch Question
If you pull on the cable housing,as long as it is unattached. The hood should open.If not,then snake your finger in behind the latch.Find the release lever and pull it towards you.
post #17 of 24 (permalink) Old 03-21-2012, 07:40 PM
bondovw's Avatar
sawzall
I tint tail lights and fix bad bondo!
bondovw is offline
post #18 of 24 (permalink) Old 03-22-2012, 09:19 AM Thread Starter
i got it open i just gotta get that little clip to make it work correctly
post #19 of 24 (permalink) Old 03-22-2012, 10:01 AM
Are you referring to the clip on the bottom of the actuator arm on the latch itself?
post #20 of 24 (permalink) Old 03-22-2012, 03:49 PM
defdaboss's Avatar
on the latch that's bolt to the radiator support. there's a hole on the bottom where u can stick ur pinky finger in. u'll feel a solid object. try to push it toward the driver side of the car. if it's a lil subborn have someone push down on the hood slightly not to put a dent and it should push over a bit easier then pull the hood up and unlock the hook.
to prevent other's from opening your hood using this method seal up that hole. or wrap ur hood shut in chain behind the hood.
(95 caprice classic tow package! 3.73, 1.6RR, beehive springs, HOTCAM, airbox delete, K&N air filter, removed mechanical fan and install electrical fan, tuned
defdaboss is offline
