94 Impala SS Radiator Selection - Chevy Impala SS Forum
 6Likes
post #1 of 36 (permalink) Old 05-17-2016, 10:45 AM Thread Starter
supersporty's Avatar
My radiator has a small leak on the drivers side near the end... I am looking to replace it, I have seen the spectras on ebay for about $115, and even some others that are going for about 80 or 90 .... Are the spectras any good, and which one do I order ??
I have a 94 SS , can anyone recommend a good radiator to throw in there ? Im down in South Florida , so it gets real hot down here, I would like to make sure I put something in thats going to do the job well..
supersporty is offline
post #2 of 36 (permalink) Old 05-18-2016, 12:32 PM
Blue Wail's Avatar
Get a radiator from Napa, Rockauto or Autozone if you like.
They all will do the job.
Nab
10.87 @ 121 mph (MD Int' Raceway 11/14/2016)
Dry 150 shot through MAF (.062 jet)
Junk 355, Stock Iron heads; CC502 cam
4500 ati Turbo 400 4.56
9C1 'Anteloupe' 3300 lb
(World's lightest full-frame Bcar)
Blue Wail is offline
post #3 of 36 (permalink) Old 05-18-2016, 03:03 PM Thread Starter
I picked one up last night on ebay... Its a Spectra cu1517. Anyone have any experience with those ????
post #4 of 36 (permalink) Old 05-19-2016, 11:51 PM
4x4high's Avatar
I'm about to purchase a Silla all aluminum from Shepard Auto Parts through Amazon for $148.
1996 DGGM Impala SS
4x4high is offline
post #5 of 36 (permalink) Old 05-21-2016, 09:00 PM Thread Starter
Is the Silla direct bolt on ? I ordered a Spectra, and will be sticking it in on Monday .... I hope it does the job.
post #6 of 36 (permalink) Old 05-22-2016, 10:51 AM
SEO9C1's Avatar
Silla -
Direct bolt on. Made in China. Welds are marginal. Pricing good. Mine has held up well for 3 years now. Main benefit is all aluminum. If it leaks, you can use low temp brazing wire WITH flux and affect repair w/ a MAPP gas cylinder. You could use propane, but it's a little tougher.
Bottom line, it's well worth it because even if it does eventually leak, you can fix it at home instead of paying too much to have it repaired or buying a new radiator.
SEO9C1 is offline
post #7 of 36 (permalink) Old 05-22-2016, 12:12 PM
When it comes time to swap rad I will go with the Silla. I like the idea of a all aluminum rad. Ther views I've seen have been good. There also seems to be a 2 row version, just not sure it's needed and they seem harder to find. This thread has some info and additional part numbers....
Unbelievable deal on aluminum radiator
Let us know what you think of your new Silla once you get it installed.
post #8 of 36 (permalink) Old 05-28-2016, 12:20 AM
4x4high's Avatar
I received the Silla radiator wednesday and the quality looks real good. Not sure what i'm going to do yet about the nipple for the expansion tank as I don't really care for the rubber caps that Dorman makes as i've seen them fail. I might have a friend just TIG a piece of aluminum over the hole after I cut the nipple off unless any of you have a better suggestion (once I get a better look if that area is thick enough i'll just thread the hole and install an aluminum plug). Unfortunately i'm still waiting on my waterpump to arrive which is due to show up on tuesday and i've got the next few weekends booked already so it's going to be about a month before I install everything.
1996 DGGM Impala SS
4x4high is offline
post #9 of 36 (permalink) Old 05-28-2016, 01:50 AM
I used JB Weld to plug it. It's held for 10 years. Then used a rubber cap just for looks.
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
grandpas wagon is offline
post #10 of 36 (permalink) Old 05-31-2016, 06:29 AM
Blue Wail's Avatar
Put a "T" in your coolant cross-over hose and run to expansion tank.
Nab
