Antifreeze Vanishing - Chevy Impala SS Forum
post #1 of 23 (permalink) Old 11-25-2016, 07:30 PM Thread Starter
I'm losing 2 gallons of antifreeze a year, and I only drive 3000 miles annually. It's not on the ground. It's not in the passenger compartment. The exhaust isn't white.
The oil looks ok, but I need to change the oil, and send it out for analysis. Otherwise there is no way to tell if antifreeze is in the oil.
The motor never had a major overheat. It's 100% bone stock. Never opened up. Original opti, original everything.
Is there any other place the antifreeze can be going ? Or is it time to pull the heads?
94 + 95 + 96 = 3
the blur is offline
post #2 of 23 (permalink) Old 11-25-2016, 08:08 PM
No on the pulling heads yet. 10 hits in .12 seconds with a search, "Pinhole"
Chevy Impala SS Forum - Search Results
Otherwise, if it took a full year with that few miles to discover that much loss, then suspect a simple open break in the system evaporating the water, v. an active leak under power. Maybe busted crossover tube grommet(s), crap cap, split tank seam, warped gooseneck....
Have you filled it back up with distilled water, bled it, and run it really really hot to see if it blows out somewhere under pressure? You have to be quick - pinholes close in a second.
post #3 of 23 (permalink) Old 11-26-2016, 03:39 PM
HUF
HUF's Avatar
Radiator side tanks are plastic. The inlet one (driver side) develops a vertical crack on the upper surface facing the grill. The crack opens up when the coolant is hot and you will not see the leak while driving. I have replaced the side radiator tanks on both my Cadillacs.
I doubt you could lose 2 gallons that way, though. Wrap up whatever hose connections you can access with toilet paper to catch the leaking coolant. Say, the connections at the heater core, plastic T, etc. This is a low-tech solution.
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 118,XXX miles.
HUF is offline
post #4 of 23 (permalink) Old 11-26-2016, 04:37 PM
2 gallons and 3K miles .. you got me on that one .
leaks will show when the engine is cold and has been sitting several hours.
cast iron heads/gaskets on these are tough compared to aluminum.
install some UV dye then when cold using a UV flash light look for the dye showing.
if its burning the coolant the spark plug will be white and very clean compared to the other plugs. spark plugs should be brown ..
j cat is offline
post #5 of 23 (permalink) Old 11-26-2016, 10:41 PM
It is possibly leaking from the heater core and exiting thru the condensation drain unnoticed. Worth a check. As stated, a pressure test is on order.
Jim B.
fbi9c1 is offline
post #6 of 23 (permalink) Old 11-26-2016, 11:14 PM
I'd look around that plastic restrictor tee.
JackFish is offline
post #7 of 23 (permalink) Old 11-27-2016, 06:47 AM
I had a leak that would pool on the intake manifold. The liquid never got to the ground, because it would evaporate before it made a big enough pool to overflow onto the ground.
1991 OCC 461 (.030 over 454) BBC, 3.23 posi, flash to pass, drop spindles & springs, Impala rims, Recaros, MOMO/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...ion-parts.html
post #8 of 23 (permalink) Old 11-27-2016, 07:50 AM
Good one. In my case it was a microscopic pinhole in the radiator hose. It never overheated, never a leak, but the fill tank would empty every 6 months. This went a couple of years, then I happened to pop the hood while running to check a squeak or something right after a run and noticed the teeny stream for only 10 seconds and vaporizing right onto a little green "mossy" looking spot on the block.
post #9 of 23 (permalink) Old 11-27-2016, 12:32 PM
HUF
HUF's Avatar
Visual inspection will be even more helpful if you increase RPMs to some 2000 by lifting up the throttle lever (next to the throttle body) by hand.
HUF is offline
post #10 of 23 (permalink) Old 11-27-2016, 02:31 PM Thread Starter
I was just under the car. Radiator / radiator supports are bone dry. No stains, no drip marks..... Nothing.
What was weird, I ran the car for 1/2 hr, with the radiator cap off. I stepped away for 1 minute, when I got back, antifreeze was gushing over the top of the coolant tank. I've never seen this happen, but I'm not familiar with the reverse flow systems. I'm an old timer from the standard flow SBC's...
Is it normal for the tanks to over flow with the cap off ?
94 + 95 + 96 = 3
the blur is offline
